Cleaning/Polishing Plastic Headlamps/Rear Light Clusters
maninthestreet Mar 4, 2010
  1. maninthestreet
    maninthestreet Active Member
    173
    33
    Is ordinary household glass cleaner/polish OK, or might the plastic be attacked/scratched by certain glass cleaners/polishes???
  2. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    Not sure what you are intending to use, but I use a very light cutting car polish via machine. Lime prime is my choice of weapon on them at the moment. Previously used Menzerna IP for a little added cut.
    What are you trying to achieve chap?
  3. maninthestreet
    173
    33
    I'm trying to achieve clean headlamps and rear light clusters, without damaging them.
  4. WX51TXR
    WX51TXR Polished Bliss
    1,452
    14
    Is normal washing with car shampoo and a soft lambswool wash mitt not doing the job then? If this is the case, a light chemical polish like Werkstat Prime Strong or Lime Prime as suggested above will do the trick nicely. Household products would probably work okay too, but no guarantees. A light chemical polish would have many uses on your car, so could be used extensively to make a puchase worthwhile and cost effective. :sm4:
