Cleaning out washer reservoir
DA4E Feb 1, 2014
  1. DA4E
    DA4E New Member
    17
    The water in my washer reservoir is absolutely foul. It fills the car with the stench of rotten eggs when I wash the screen. It would be nice to drain the water out completely and wash it out with something but it looks as if that is easier said than done. A while ago I tried just poking the hose in there and letting it run for a good while but that hasn't sorted it out. Any ideas, maybe something I could add to the water or is there a way to get to the reservoir and clean it properly?
  2. Daggerit
    Daggerit Well-Known Member
    1,139
    194
    I don't really know but maybe mixing 50/50 water and vinegar? Put it in, leave for a while then run it through the system? Maybe do it a couple times?
    NHN likes this.
  3. NHN
    29,300
    1,702
    That's exactly my suggestion, but empty the water via jets & stick a small bottle of vinegar inside, leave it for a day, then dilute to top with water, leave for a day then flush it all out few times, maybe as above do a few times.
  4. DA4E
    DA4E New Member
    17
    Trouble is the reservoir is almost full to the top. I don't know how much they hold, but emptying it via the washer pump?
    Worried it might damage the pump itself by over-using it. I suppose I could empty it over a good few hours and allow the pump to rest a bit between blasts. The smell is unbelievable. God knows how long the water has been in there. To be honest I find few occasions when I need to use the washers very often, more often than not its p'ing down anyway and the rain does the job. My last car was the same actually, and the bottom of the reservoir had a thick layer of black gunge that stunk to high heaven. But the res' was much more accessible so I took it off and cleaned it out.
  5. NHN
    29,300
    1,702
    Never had this issue on numerous cars tbh, just pump it out, the pump will be fine, they hardly ever go faulty from years of usage.
  6. Christian_a4
    Christian_a4 Member
    61
    17
    I use halfords advanced concentrate screenwash ( more cost effective than ready mixed s/wash) i get the apple flavour and it smells fantastic i advise doing the above tips a few times then putting this in near 100% neat!
  7. Mike_B
    Mike_B Active Member
    533
    47
    Pop the pipe ends off the jets and just empty the reservoir with the pump. Then follow the vinegar advice, a few times if necessary. Again, I'd suggest emptying the reservoir with the jets disconnected as you'll probably have a lot of calcium in the tank if you live in a hard water area, and the vinegar is going to dislodge this, which will in turn block the jets.
  8. DA4E
    DA4E New Member
    17
    I'll give it a go then. Just wondering whether Halfords do a fish'n chip flavour screenwash? What with all the vinegar in the tank it would smell great.
    Thanks all.
  9. Christian_a4
    Christian_a4 Member
    61
    17
    Possibly haha just ask them!
  10. rum4mo
    rum4mo Well-Known Member
    1,076
    196
    This is a bit weird, I'm same as NHN, ie never had this issue before, though I've always used a "correct" additive. I've seen this reported before recently, either on this forum or another Audi related forum or maybe another VAG forum, sounds a bit nasty.
  11. Anthony566
    Anthony566 Active Member
    732
    111
    43
    I have had this is the past I can only assume that one of the windscreen liquids I had used did not mix well with what ever was in there so I emptied it out via the jets and put neat Audi screen wash in an pumped a bit through the jets and just used it neat for a few weeks then 50/50 for a bit longer then down to the correct mix and the smell never came back.
  12. kanecullen89
    kanecullen89 Active Member
    569
    160
    43
    I had this exact problem recently. I had audi screen wash in it and mixed a whole bottle of another brand wash in and they must have reacted with each other or something cause it stank!! Same rotten egg smell.
    I emptied the tank with the washers, doing it in 5 second blasts. Only took about 5 minutes.
    I then refilled it with fresh screen wash and water and it smells lovely again :)
  13. SI-W85
    SI-W85 Well-Known Member
    1,321
    351
    Could always try Milton steriliser that may work and won't smell anywhere near as bad as viniger.
  14. DA4E
    DA4E New Member
    17
    The steriliser sounds like a good idea, I have some in the cupboard. I'm going to drain it tomorrow and sort it out. I think I am partly to blame, I have had the car for 18 months now and have only topped the washers up once, and then it took very little. I just don't find the need to use the washers much, so the same water has been lying in the tank since before I even owned the car. Not ideal I suppose. As I say the exact same thing happened to my previous car so it looks like its down to me.
    Note to self: Use your b***** washers more frequently man!
  15. jpda4
    jpda4 Member
    125
    21
    i had this problem a few weeks ago.....
    cured mine by flushing out with hose pipe and adding fresh additive, 50:50 mix
    have emptied that tank full and added some new mixed to correct ratio..... no more bad smells
  16. dubdemand
    dubdemand VAG Addict
    405
    Its a 5l tank for the washers by the way... I only comment as I filled ours from empty the other day and it took just under 5l to completely full - which seems logical as the tank wasn't completely empty.
    The tank it self doesn't appear to be easily accessible and seems to be towards the back of the engine given the location of the filler neck... ideally it would be best to take it out of the car and flush it out but this could be a major headache? Suppose it depends how long it takes to empty 5l of fluid via the pump and how many times you want to flush it through using that method.
    I think I'd strip off some of the engine covers and see how easy it would be to get to it, remove and do properly to be honest. Let us know if you have a go and how you get on :)
