Cleaning exhausts, best product/process?
razza1 Jun 2, 2011
  1. razza1
    razza1 Well-Known Member
    3,072
    825
    HI, the miltek's seen better days, what's the easiest way to clean it back up? I've got metal polish but after giving it a blast, there's still loads of black deposits on it.
    Should I take a scourer pad to it? Or will this end up scratching it?
  2. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Use steel wool, buy both types. Mix a little dab of metal polish paste onto the wool and plenty of elbow power.. I will be doilng my full system soon.. Once you have borken down the black spots you can just use metal polish and a cloth to work on the shine..
  3. razza1
    3,072
    825
    sorry, what do you mean by both types?
  4. mad cornish pastie
    mad cornish pastie Audi novice handle with care
    81
    autosol is great stuff....
  5. CMD
    3,015
    17
    Fine grade 00 Is for finish (use 2nd)
    Grade1 is for preparation (use 1st).
    Grade3 is for rust removal/ very coarse..
  6. Farhan
    Farhan Active Member
    1,234
    57
    both types of wire wool he meant. You get different grades. Go for a heavy/medium and fine. Work your way up, I think heavy may be overkill start with a medium with some metal polish.
  7. razza1
    3,072
    825
    thanks guys:thumbsup:
  8. John @ PB
    John @ PB Member
    360
  9. razza1
    3,072
    825
    hmmm, maybe I'll just have to get out the elbow grease then...
  10. 1animal1
    9,978
    dont know about you guys but the tips on my last two cars have hardly changed with any grade of wire wool, autosol or indeed the Britemax twins
    Ive ended up using a wire drill bit (sometimes a grinding bit!), then reducing the grades and finishing off with a wool bit used in conjunction with autosol - worrying as you scratch the **** out of the metal, but its soft enough get polished back up and far more effortless than wire wooling your life away
    just what works for me, i assume i'll get shot to **** now :)
  11. weela89
    weela89 Member
    64
    Autosol is actually the best ive come across. Will get anything out.. well maybe not anything.
    I need to do mine this weekend so i hope i dont eat my own words! haha
  12. razza1
    3,072
    825
    autosol worked (found some in the garage) with some wire wool, followed my meguirs metal polish, was a bit late when I got started so hopefully in daylight it will look good :) the insides need something harsh to get clean though
  13. razza1
    3,072
    825
    still very black inside, the wool made no impact on it at all
  14. rowdyboy
    rowdyboy Member
    804
    19
    Autosol, a rough polishing cloth and elbow grease. Mine came up like new.
  15. S4twiggy
    S4twiggy Fully Certified Detailer!!
    1,815
    9
    some serious swirling in that paint mate lol(thats the detailer in me lol)
    looking good mate, Autosol is tip top when it comes to metal. how bad were the exhausts in the first place, wouldnt of thought a milltek on an 07 would be that bad. should be able to come up a treat inside and out:thumbsup:
  16. razza1
    3,072
    825
    I know, its not great all over to be honest, the tip edges of the exhausts were quite bad, the rest came up really easily, not much elbow needed to be honest
    The inside seems very caked in stuff, was late though and was tired, so couldn't be bothered to try any more, will try again later this week on the inside.
    What's a rough cost of detailing to get rid of swirl marks (over the whole car...)?
