Cleaning exhaust pipes, getting them back to their original colour
thomasedwards Apr 20, 2013
  1. thomasedwards
    thomasedwards New Member
    I’m trying to clean off the rubbish on my exhaust pipes, but it won’t budge. I’ve tried using T-Cut Metal Polish, but it won’t shift all of it, just a couple of easy bits.
    Any suggestions?
  2. Molnboman
    Molnboman Well-Known Member
    1,338
    194
    Maybe something a wee bit more agressive , I used a Swedish vesion of Autosol Metallpolish - Biltema and they came up brand spanking! Just need a good bit of of elbow grease!
    Good Luck
    A
  3. Cozza McA
    Cozza McA Crunching The Gears VCDS Map User
    410
    74
    Wire wool looks like the best thing for those pipes.
    Just work down the grade of roughness
  4. willowsdad
    willowsdad Sideways
    1,027
    32
    Metal polish and 00 grade wire wool. If that doesn't shift it then move up a grade then back down. It will take a lot of elbow grease, so be prepared for arm ache. You can get drill attachments but I've never gone down that route.
  5. Steve220
    Steve220 Member
    234
    15
    Autosol with wire wool. Works every time.
  6. dieseldoos
    dieseldoos Active Member VCDS Map User
    206
    97
    +1. I did this last year, it took a little while but they are like mirrors now. All I do is give them a quick once over every now and then to keep them looking that way.
  7. thomasedwards
    Thanks for the advice everybody – will give you an after photo to compare against the before.
  8. dieseldoos
    206
    97
    6 months on, and mine still look like this with a quick wipe every time I clean my car.
  9. JimC64
    JimC64 Active Member
    246
    29
    A Huge +1 from me on the 0000 wire wool and Autosol polish.....a little hard work and you will prevail.
    Personally, I include them ALWAYS as part of my wash routine, it only adds a few seconds and soooo worth it.
    Mine are nothing special, just standard but still look like new after 6 years and 102k miles, as below
    Sorry, no close up pics
  10. BradA3
    BradA3 New Member
    12
    Do you need to remove the rear bumper to access this?
