Cleaned Throttle Body
Defratos Jun 30, 2007
  1. Defratos
    Defratos You’re Dethpicable!!
    2,232
    Hey guys, just thought I'd share a few pics of my weekend maintenance Session: First of I cleaned my Air Filter, MAF and then moved onto the Throttle Body:
    Dirty
    By this point my finger was bleeding which Is why I chopped it out of the pic lol.
    Managed to get a lil look inside the manifold as well.
    Cleaned
    :beerchug:
  2. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    See how rough cast the intake manifold is inside? I spent 3 days polishing my MK2 escort intake manifold back in the day, it looked like a mirror when it was done.
    Then I put on twin 40's so was a bit pointless anyway, looked great though.
  3. Defratos
    2,232
    That must have taken you a while, although I'd probably do the same if I had the time and know how :beerhcug:
  4. mattyboy199
    mattyboy199 Well-Known Member
    1,890
    29
    what about idle control values sorry to hi jack, do these engines have them ?
  5. mwstewart
    mwstewart Member
    199
    Good work. Just a pointer for future reference. The TB butterfly has a special 'anti stick' coating and should not be cleaned, I've always found they need cleaning eventually anyway though!
    Something beneficial for another weekends work would be to clean the breather system and associated tubes :drag:
  6. Defratos
    2,232
    Where/ What exactly is the TB butterfly? is it the gasket you're talking about? and does the pipe on top of the throttle body come off? because I took the clip off but the pipe seemed welled on somehow. If you're referring to the IC pipes I've cleaned them as well, thanks for the helpful feedback :beerchug:
