Cleaned Throttle Body......
johnie72 Apr 20, 2007
  1. johnie72
    johnie72 Member
    68
    Just got the car back from GCS nr Horsham. They did a cambelt change, thermostat, water pump, etc.... While they had the car I asked them to clean the Throttle body and change the gearbox oil (manual).
    What a transformation, the throttle response is now razor sharp and the gear change very slick. The engine also feels very crisp and strong. :icon_thumright:
    I would seriously reccomend anyone with a 2.8 30v gets their throttle body cleaned if it has anything like highish miles. The guys at GCS said there was loads of **** in there. Also the gearbox oil is well worth changing. It has totally transformed the gearbox which, to be honest, I tought was starting to feel very tired and baulky. Top work GCS........:respekt:
  2. Rich
    Rich Rollin on boost mother hubbards
    373
    My gear changes are feeling a bit clunky recently (although I think my clutch is on its way out) might get the garage to change the gear oil as well then when its in, or is it possible to change the gear box oil easily yourself?
  3. Broken Byzan
    13,237
    465
    To chnage the gearbox oil your self ,you will need to buy the spline tool to undo the drain and filler plugs.Otherwise its dead easy once the undertray is out of the way
  4. Rich
    373
    Does it take the same oil as the engine? Or do I need to buy some other shiz? 1.8T Engine btw if its different?
  5. Phantom_A4
    Phantom_A4 Member
    563
    Hi Johnie, i live near Horsham, in Southwater :)
  6. Broken Byzan
    13,237
    465
    Nah mate, its a different oil altogether, a fully synth gear oil is supposed to be good for it. I have the spline tool here you could borrow, but i would need it back before 14th may as thats when my transplant takes place
  7. johnie72
    johnie72 Member
    68
    Hey Phantom - I'm in Steyning. Really rate the lads at GCS, they know they're stuff.....
