Clean Air Con
jdp1962 Dec 11, 2005
  1. jdp1962
    jdp1962 Grumpy Old Moderator Staff Member Moderator TFSI Owners Group Team V6 Gold Supporter Team Tornado Audi S4 quattro Black Edition s tronic
    8,598
    3,173
    My wife was complaining on Friday that the inside of the car smelled like cat pee, so I figured it was time to disinfect the air con.
    Popped into Halfords on Saturday & picked up one of those Comma anti-bacterial cleaners. I've used it before & it's very effective. All you do is move the front passenger seat fully forward, & place the canister on the rear footwell. Next, start the engine, switch the air con to recirculate, and put the fan on full speed. Finally, hit the button on the canister, lock it open so the aerosol spray is fixed on, & close the door. Ten minutes later, the canister is empty, all the cleaning stuff has been sucked right through into the system. Job done!
    While I was at Halfords, I noticed they sell replacement cabin pollen filters now, so I bought one, as the filter hasn't been changed at least as long as I've owned the car (2 & a half years), & probably a lot longer.
    It took old Captain Sausage-Fingers here a few minutes to undo all the clips & covers, but when I eventually found the old filter & pulled it out, it was minging! No way will I leave that job so long again!
    It smells very sweet inside the car now. The Comma cleaner is an excellent product, but you do need to give the interior surfaces a good wipe-round afterwards.
    /ubbthreads/images/graemlins/ok.gif
  2. 1.8TCraig
    1.8TCraig New Member
    Just gave the Comma product a go dude on the strength of your reccomendation and I have to agree with you - it's a very good product and well worth the ten quid or so it costs:)
  3. tracer
    tracer '96 a4 1.8 se
    266
    sounds good, will give it a try :beerchug:
  4. Aldo
    Aldo Active Member
    1,017
    12
    Please can some 1 tell me where the cabin pollen filters are?!
    I have a 03 B6 A4
  5. cdb2
    cdb2 Member
    711
    How much mess does it leave and what sort of mess?
    Does it end up all over the dash pod?
  6. topscaff
    topscaff New Member
    23
    I think i will be paying a visit to halfords tomorrow to give this a try, cheers.
  7. jdp1962
    8,598
    3,173
    Easy. Open up the bonnet. At the back, behind the main engine bulkhead. to the right of the battery. Remove the rubber beading from the front bulkhead, unclip the full width cover, then tease out the plastic cover to the right of the battery (you'll need to unclip a tube that runs across it). The pollen filter is underneath.
    Remove, replace, re-fit, job done. Takes 10 minutes.
  8. jdp1962
    8,598
    3,173
    Just a fine mist. Wipe it over with a clean cloth & you're fine.
  9. Aldo
    Aldo Active Member
    1,017
    12
    Will take a look tonight or tomorrow, I saw you cleaned yours in washing up liquid, but did you then buy a new one, just wondering if I should just go out and buy a new one or not?! :)
  10. bainsyboy
    bainsyboy Guest
    I use it every year and does make a difference, leaves a slight mist on speedo etc but wipes off easily enough.
  11. jdp1962
    8,598
    3,173
    I didn't buy a new one, cos the washing powder did a good cleaning job (even if the thing smelled of Daz for a week afterwards). Dealer put a new one in last week, though, as part of service.
