Clattering Noise!
Funkyfin2000 Jun 19, 2012
  1. Funkyfin2000
    Funkyfin2000 Member
    489
    Hi guys,
    If you read one of my other posts a while back I was having a clattering/banging noise on start up from my Audi A4 1.9tdi 2004 Quattro....Only happened occasionally on start up and slowly its got worse.
    It now happens really when in gear, under very low revs and low speed.....The noise a loud clattering/tapping/banging noise....
    I have a suspicion this is probably the DMF, but how would it make such a noise?
    Any ideas for this?
    Cheers, I know it's a long shot!
    Rich
  2. Funkyfin2000
    Funkyfin2000 Member
    489
    Any ideas peeps?
  3. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    possilbe has it had the correct oil changes etc does it sound like the bottom end going, unlikley but just go single mass if it is the dmf
  4. Funkyfin2000
    Funkyfin2000 Member
    489
    Hmmmmmmmmm yeah has had oil changes fine and had all the top end checked fully for camshaft wear and all that!
  5. Mr.Vagcom
    Mr.Vagcom New Member
    26
    Its possible that it could be pas pump .... or AC pump but possibly more than likely its your oap there really common for going.
    Regards
  6. Leaky Lloyd
    Leaky Lloyd Member
    293
    ive had a similar problem and posted in other threads of similar discriptions and my problem is now 100% solved !
    it turned out to be the air conditioning pulley
    heres what you need to do to test it,
    start the car for maybe 30 seconds just to check the noise is there but dont let it warm up !
    then,remove the belt which goes around all the pulley's at the front of the car (christ knows what its called im not a mechanic)
    start the car (BUT ONLY FOR A COUPLE OF MINUTES!!!!!!), if the noise is gone then your half way there
    now, the air-con pulley if i remember correctly is (as you stand infront of your car) the one to the right hand side right down at the botttom.
    with the engine off,, rotate this wheel by hand bock clockwise and anty clockwise say 5mm in each direction as fast as you can, and also try rattling it on its axis ?
    as soon as we did this we knew we had the problem nailed,
    changed the pulley, slipped the belt back on and bobs your mothers brother,,,, problem solved !
    good luck with it matey !
  7. Funkyfin2000
    Funkyfin2000 Member
    489
    Ive had the common alternator pulley changed when I had the car 2 years ago in Nov....can't see it being that again..... is that the same thing????
    Is this the air con one different presumably do?
    Its making the noise on Idle as well, just clatters quite regularly when idling! Annoying!
  8. Leaky Lloyd
    Leaky Lloyd Member
    293
    same sort of problem,, different pulley !
  9. Funkyfin2000
    Funkyfin2000 Member
    489
    Guess what, it's the Air Con Compressor Clutch! Great :( £430 fitted!
  10. boost-addict
    1,000
    39
    at least it wasnt any thing to do with the mechanical side of things (engine wise) so at least its a straight forward job
  11. marktdisport
    marktdisport Active Member
    1,195
    15
    pm leaky lloyd m8 as he fixed his for cheap im sure it was only around £30 quid fix to reasemble the clutch and this would save the expensive new compressor
  12. Funkyfin2000
    Funkyfin2000 Member
    489
    Thanks mate, have PM'ed him but no reply.
    Rich
  13. Andy021
    Andy021 New Member
    25
    sorry to resurrect and oldie but here to help!
  14. Mike.M
    Mike.M Well-Known Member
    2,477
    169
    I had a clattering in mine like that and was told it was the air con, but refused to believe it.
    I had a new belt on already as had that changed at the cambelt, so, changed the air con pulley and that helped a little (my buffer bushes were fine, slight play with bearing with some improvement in noise), then replaced the tensioner as it was bouncing (that helped a little too), then changed the alternator pulley for good will (no difference) and finally got to the main culprit......the idler pulley, changed that and silence!
    That idler pulley had loads of play in the bearing as guess 10 years or the 65k miles my car has got the better of it, but it only made real noise when the air con was on and at idle......turn air con off and the noise went, so gess the extra strain showed up its weakness.
    As usual for me, it was the last thing to change LOL, but all sounds healthy again but think it all needed to be done anyway due to the age of the car
  15. Andy021
    Andy021 New Member
    25
    wow, triggers broom comes to mind!! I haven't done it yet so will check out that idler, the a/c pulley is slack though. top tip thanks
