Chrome trim and aluminium roof rails......
DALE_AVANT Mar 20, 2012
  1. DALE_AVANT
    DALE_AVANT Member Audi A4 Audi A3 Audi Avant Owner Group Team Brilliant Black TDi
    626
    21
    Hi all.
    Has anyone found an effective way of restoring the chrome window/grille trim and the aluminium roof rails?
  2. yy54cnk
    yy54cnk New Member
    27
    Werstatt Prime, the acyrilic one sorts out the trim and roof rails:icon_thumright:
  3. DALE_AVANT
    626
    21
    Good stuff, thank you for the recommendation.
    Does this remove the water stain marks (that's what it looks like?) from the plastic chrome and the alu roof rails?
    I was tempted to give Autoglym Super Resin Polish a gentle go to see if this would do the trick.......
    Any other tried and tested methods/products?
  4. DALE_AVANT
    626
    21
    Anyone have any thoughts on the Autoglym SRP?
  5. Wozski
    Wozski Member
    522
    Bump...
  6. Juicy Jen
    Juicy Jen Jen @ Juicy Detailing Site Sponsor
    828
    121
    Try a small area first but it should help and then get some sealant on to help protect :)
  7. DALE_AVANT
    626
    21
    Do you mean the Autoglym SRP Jen? Suitable for both plastic chrome trim and alu roof rails?
  8. Juicy Jen
    828
    121
    Yes
  9. DALE_AVANT
    626
    21
    Good stuff, I'll give it a go and report back to all. If that doesn't work then Werkstat Prime Acrylic will be my next port of call. Cheers
  10. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Any luck with this? My chrome trim around the windows is quite hazy and looks like its turning white. :sadlike:
  11. scotty76
    scotty76 Well-Known Member Team Phantom Audi S4
    3,134
    1,884
    This has happened to our VW Jetta and won't polish out so I assume something has got underneath the surface of it. Best suggestion is to try some polish and see it if helps. It won't make things worse.
  12. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    The milky appearance of a chrome trim is due to water ingress/ageing.No amount of polishing will sort it as it is underneath the clear plastic top layer.Only replacing will fix.I had two bits go on a 12 month old car that were done under warranty, but in your case itll be new ones.Soz.
  13. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Anybody know what kind of difficulty I would be looking at in changing these? I've heard the ones around the small window of the rear require the glass coming out?
  14. DALE_AVANT
    626
    21
    Hi all, an update.
    In the end I made gentle use of Autoglym Paint Restorer on the chrome trim and roof rails. Brought everything up a treat
  15. scotty76
    3,134
    1,884
    Ah, interesting. I'll give that a try.
  16. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    Thanks for that, will give it a go and maybe post results too if I remember.
  17. DALE_AVANT
    626
    21
    No problem.
    If you use two ordinary polishing cloths, rub the polish gently onto the rails and trim until you see the water stains disappear. Let it haze then buff off with the second cloth. Should be nice and shiny after that.
    Prob should use some sort of wax/sealant after but I'm no expert on that
  18. scotty76
    3,134
    1,884
    What do you have to hand? Nothing special needed, any kind of wax/sealant would offer some protection and will be better than nothing. Slap it on. :)
  19. DALE_AVANT
    626
    21
    I have nothing to hand haha, would need to buy something for the job
  20. JDM82
    JDM82 Member
    328
    I had this problem with my chrome window trim on my A4. I bought the replacment trim, which was very expensive and very very difficult to fit so instead I choose to sell the trim and go the vinyl wrapping route which was definately the way to go. I had all my trim wrapped in gloss black. Including my grill. I got a professional wrapper to do it and all in cost £100. That was a year ago and all's well.
  21. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    You got any pictures? I was thinking about this too but unsure on the final outcome and if it would look tacky around the edges where the wrap finishes.
  22. A4_MaJiK
    A4_MaJiK Azeem
    924
    109
    43
    So had a spare 10-15mins yesterday and decided to give it a try. Here are the results after one hit of AG Paint Renovator:
    BEFORE
    AFTER
    May give it another try when I get some time. Any other ideas anyone? How much do you think it would cost getting them replaced?
