Chrome Tailpipe Covers for downwards TDI pipes?
Gee. Apr 12, 2010
  1. robby
    robby Active Member
    579
    69
    I could only use 2 bolts in 1 of the trims as well, the missing bolt was too close to the other :)
  2. haider
    haider New Member
    10
    Would these chrome pipes fit an diesel audi 1.9 TDI? 57plate
  3. warrenlord
    warrenlord Member
    771
    15
  4. Ash187
    7,485
    738
    Actually i would say it looks OEM, the Audi ones i got looks pretty much the same except instead of bolts i have allen screws
  5. Gee.
    Gee. The Dynasty
    151
    They're definitely the same mate. The pics look the exact same as the ones I received.
  6. warrenlord
    warrenlord Member
    771
    15
    yep sorry your right
    looking to close into things. i know its 15ish days but how long was yours?
  7. Gee.
    Gee. The Dynasty
    151
    Mine took 13 days, including weekends.
  8. c_w
    c_w Well-Known Member
    1,163
    87
    They look like a much better item than the OEM ones, which I think really are supposed to be fitted on straight pipes, like the DPF models.
    The ebay pipes look a bit longer which is helpful.
  9. Blackie
    Blackie Active Member
    697
    67
    I've just ordered some so we will see how they fit soon. It's in at awesome next week for a remap and the front sprngs fitted
  10. Blackie
    697
    67
    UPDATE
    I ordered the Chinese tailpipes & they arrived yesterday. I decided that the brackets & bolts that come with them should go in the bin.
    I found some other bolts for the 2 top fittings of each pipe & cut them down so they did,nt stick out.
    They slide right over the endcaps without any mither. Underneath the pipe i drilled using a cobalt drill bit as the pipes are hard. I then used an orbix self tapper to firmly hold them in place, they are not coming off.
    I did stick them out a little as i preferred it like that. They dont look too in yer face & you cannot see the original end caps at all.
    Overall an excellent mod for a fiver, They even remind me of the Milltek end caps that were on my A6 estate.
    I would love to post some pics but i cant...I,m not allowed
  11. Gee.
    Gee. The Dynasty
    151
    ^^Nice.
    Go on, get some pics up!
  12. vw754
    vw754 vorsprung Durch Technik
    2,331
    58
    ive took the factory fitted down pointing tips off my A3 2.0 TDI (140) anyone any ideas what size exhaust trims i need i think if ive measured right there.75mm? but ive been told they could be 55mm??????? can anyone let me know before i order off flee-bay
  13. vw754
    2,331
    58
    can you tell me what mm the tips are ? i.e the bit that sticks out the exhaust?
  14. Ash187
    7,485
    738
    I will have a look for you tomorrow and let you know
  15. warrenlord
    warrenlord Member
    771
    15
    just sorted out my rear bumper and fitted these. they aren't the perfect fit for my but thats because it an 09/10 bumper,
    trouble is hows everyone doing with the splattering? ive only just done a short journey and the cars plastered in black dots!?
    whats the solution ? will pulling them further forward solve it as i have the room too without looking poop
  16. Blackie
    697
    67
  17. warrenlord
    warrenlord Member
    771
    15
  18. Blackie
    697
    67
    No mate
  19. lozhoon
    lozhoon New Member
    23
    hi gee, is this the correct item on ebay? 170529386820
  20. lgooch
    lgooch Well-Known Member VCDS Map User
    1,139
    149
    are you guys fitting these to 2.0Tdi or 1.9tdi
    I have a 1.9tdi sport with the downturned pipes and I am wondering if this will fit.
  21. Gee.
    Gee. The Dynasty
    151
    They look the exact same in the photo, but I'm not sure what size they are.
    Btw, I've never had a problem with 'black dots' like warren said.
  22. S3mad
    S3mad Dark Knight
    946
  23. lozhoon
    lozhoon New Member
    23
  24. Gee.
    Gee. The Dynasty
    151
    Mine didn't have a cover on them to begin with, so you don't need to remove anything mate. Just slot the new ones over the old ones :)
  25. Blackie
    697
    67
    Mines a 2.0 tdi but i would think the back box is the same, but i,m sure someone will tell me i,m wrong
  26. fresh1
    fresh1 New Member
    I have an A6 2.0TDi with a single downward pipe exhaust on either side. So, after reading this thread I'm guessing I dont need to cut the downpipe? So, anyone recommend a suitable single tailpipe cover?
    As an alternative, what do you guys think of something like this:
    70MM CHROME EXHAUST TRIM/TAILPIPE MOTORHOME/CAMPER VAN on eBay (end time 24-Sep-10 11:03:31 BST)
    Its basically a cover modified to fit downward pipes, allowing fumes to exit as normal but giving the appearance of a straight exhaust. Personally, not for me as I think it will be a mission to get straight and will look bad from sides/close-up.
    Any help would be appreciated.
    Cheers.
