Chrome Tailpipe Covers for downwards TDI pipes?
Gee. Apr 12, 2010
  1. Gee.
    Gee. The Dynasty
    151
    Anyone know if there are chrome tailpipe covers for the 'droopy' pipes on earlier (2003/04) A3's?
    If so, where can I buy them? and are they easy to fit? thanks.
  2. mike foster
    3,967
    They are available direct from Audi, but at a price.!!
    I'm sure I've also seen them on ebay but can't remember where - sorry.
    Problem is you have to hacksaw the originals off first and I didn't fancy that !
  3. Ash187
    7,495
    744
  4. Gee.
    Gee. The Dynasty
    151
    Thanks guys. Are they much hassle to install?
  5. c_w
    c_w Well-Known Member
    1,163
    87
    There's a thread whereby people are buying the later 170 tail finishers (straight pipes), but you have to grind off the existing covers, then grind the "droopy" end off so the pipes are striahgt, then put the new finishers over them. However, they seem to sit in the bumper quite far (looks fine from behind but from the side they could do with being about 20mm longer).
    That ebay link states for cars with a bigger rear bumper/skirt so they may well stick out too much on normal bumpers!
  6. Ash187
    7,495
    744
    well you could always just take the part number and just got to the dealers and ask how it should fit? im not going to do this mod quiet yet as i have lots on my list which the rear bumper diffuser is one of them.
  7. A3TDI2.0
    A3TDI2.0 Member
    50
  8. Gee.
    Gee. The Dynasty
    151
    Thanks for the advice everyone :)
  9. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,451
    589
    You would be best, cosmetically, to go to the likes of powerflow, have the current turned down pipes cut off and weld on a set of new, straight pipes - will look a lot better than turned down chrome.
  10. Gee.
    Gee. The Dynasty
    151
    Good idea Boydie, may do that instead!
  11. robby
    robby Active Member
    579
    69
  12. Ash187
    7,495
    744
  13. robby
    robby Active Member
    579
    69
    nope - the trims slid on straight :icon_thumright: if you bend down and look directly into the exhaust you can just see the downturned trims but in a couple of days the soot will blacken them
  14. Ash187
    7,495
    744
    in the pic the tailpipe looks straight... so what do you do about the black thing? could you cut the end of the existing pipe a lil so it does not go straight onto the trim?
    does the trim stop the fumes from coming out the exhaust?
  15. robby
    robby Active Member
    579
    69
    The black part of the bumper has a cutout for the exhaust so the trime fit perfectly
    you could cut the existing trims but i only had a dremmel and it wasn't making any impact - the new trims don't obstruct the tailpipe exit so fumes can get out
  16. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    Sorry Robby, but I am trying to get my head around your exhaust trims :)
    So you are saying they are not actually attached to your standard exhaust?
  17. 4NT
    4NT Terminal Douche Bag!
    368
    I read it as though they've been forced over the standard downfacing trim. Although I think it'd have to be a massive diameter.
    Need better pics I think, Robby?
    P.S. Scottie, damn your car looks good.
  18. robby
    robby Active Member
    579
    69
    The trims are bigger so fit over the existing trims, then bolts are tighten through holes in the trims to make sure they don't move
    I'll try to remember to take some pics after work tommorow from directly behind so you can see inside - piccies save a thousand words :)
  19. scottie123
    1,972
    Yeah I thought that also 4nt, but then thought as you say, the trim diameter would have to be mahoosive!
    Oh, and thanks for the comment! It's slowly getting there now :)
  20. scottie123
    1,972
    Still cant picture it. !!! Surely if the original droopies are still on, the trim will have to bigger than a halfords special!
    Need to see pic's I think!
  21. robby
    robby Active Member
    579
    69
    They do look like i've got an aftermarket exhaust but they fit in the cutout nicely - piccies tommorow
  22. 4NT
    368
    Look forward to seeing the pics and understanding it then coppying it! Cheers Robby.
  23. Ash187
    7,495
    744
  24. 4NT
    368
    wasntme, they are the ones that you'll have to remove the outer downpointing trims for, be interesting to see what they go for... Well spotted
  25. Ash187
    7,495
    744
    so how do you keep it so clean? i used to have a factory chrome exhaust on my focus where the tip would end up getting black and it was a b*tch to keep clean.
  26. Ash187
    7,495
    744
    im a bit lost with this... if you remove the down pointing one then how do you fit these? is there any pipe left to attach the finisher on?
  27. 4NT
    368
    The backbox has it's 2 exit trims pointing straight out and then the downpointing trims are tacked on at manufacture, you can saw them or angle gring them off (there's a few threads with this shown, worth doing a search) and then you are left with the straight bit, just attach the trims, weld or screw them up tight and it's done!
  28. Ash187
    7,495
    744
    ahh i see, i thought the downward pipe came straight out of the backbox. have'nt got on my knees to see the exhaust yet... still excitied of getting my first audi :)
  29. N8
    17,163
    718
    I bought wolfrace pipes and had them welded on, but afterwards I decided they were 2 small, ended up going for a turboback exhaust which is perfect for looks and noise :wub:
  30. Ash187
    7,495
    744
    hey N8, on another thread you posted up your sportback, can you tell me what rear bumper you have?
  31. N8
    17,163
    718
    My standard S-Line numper that came out the factory with a 09 S3 Sportback valance added.
  32. Ash187
    7,495
    744
    aahhhh... my bumper has that trim thing going around it and i was wondering how your one was so smooth. how much did the valance set you back? i want one of those.
  33. N8
    17,163
    718
    The 09 valance is in 2 parts, its over £200 + spraying. Yeh S-Line bumper is same as S3 bumper.
  34. Ash187
    7,495
    744
    The price we pay to look good eh!
  35. N8
    17,163
    718
    Add that to everything else and its very expensive game :laugh:
  36. scottie123
    1,972
    Tell me about it :faint:
    And as soon as you think you are near the end of your list,some clever 5h1t does something to their car, and your list grows again.............................
  37. N8
    17,163
    718
    I'm hopefully coming to the end of my list :ninja:
  38. Ash187
    7,495
    744
    :idea:does that mean its nearly time to sell the car and buy a new model A3 to start all over again
  39. scottie123
    1,972
    I have thought that several times now.............
    LMFAO
  40. N8
    17,163
    718
    Nah, it means save up and buy a TT-S for missus, I won't be buying another A3 after this car dude.
