Chrome Indicator Bulbs, will they fit ,.?
Julz.S3 Jul 28, 2010
  1. Julz.S3
    Julz.S3 6th Gear
    Hi Guys,
    Could anybody tell me if these bulbs are going to fit my S3, am just not sure about
    Offset Pins.
    I've just got a bit of change left it my PayPal account, and feel like a cheap mod.
    Thanks for any help you can give me.
  2. Julz.S3
    Julz.S3 6th Gear
  3. 1animal1
    9,976
    they should do.... just check what bulbs it normally has, ie 581?
  4. mattyboy199
    mattyboy199 Well-Known Member
    1,882
    580 off set pins are the ones you need, their on ebay
  5. Julz.S3
    Julz.S3 6th Gear
    ooh,**** i just order the 581 fitment, will these not fit then ?.
    why do people on ebay say things fit the s3 98>, when they dont.
  6. Dazboss
    Dazboss Like A Thristy Dingo ;)
    366
    Yes they will mate don't worry. The bulbs you need are 581 Offset pins :):)
    Brake light bulbs are 382, rear fog & reverse are 380, rear indicator bulbs are also 581.
    HTH..
  7. Julz.S3
    Julz.S3 6th Gear
    Dazboss,,,,thanks for the reply,i got these for the front indicators, do you have them fitted ?
    I hope your right,,i have just sent a message to the guy on ebay saying they give a misleading description of the item, oops.
  8. Dazboss
    366
    No probs. Well i brought a cheap set like them but a bulb blew, so i brought a set of Phillips Silver vision's & received a replacement set for the blown set ( which i gave away last nite ).
    Reason why they put S3 etc.. is it comes up more in the searches.
    Tip: When buying bulbs from ebay dont search using you car make & model. Use the bulb number as most the time the listings with the make & model are nearly twice the price for the same item :)
  9. lloydsta101
    lloydsta101 Member
    134
  10. Dazboss
    366
    Get Silver Vision's mate. worth the extra few pounds.
  11. 1animal1
    9,976
    yup another one for the philips
  12. Broken Byzan
    13,235
    464
  13. Dazboss
    366
    FTMFW ???
  14. mattyboy199
    1,882
    sorry guys i could be wrong your ll soon find out anyway
