Chorus » RNS-E sat nav Retrofit
Discussion in 'A3/S3/Sportback (8P Chassis)' started by johnmv55, Nov 28, 2006.
  1. johnmv55
    johnmv55 Member
    Dec 5, 2004
    247
    All this Sat Nav talk at "Symphony II » RNS-E sat nav Retrofit" has got me quite interested, has any body carried it out with a Chorus radio? Looks to me as if I would need a new carrier for the hazards and also a new ECC unit?
  2. Advert Guest Advertisement
  3. steve1975l
    steve1975l Member
    Jun 14, 2004
    595
  4. benw123
    benw123 Moderator
    Oct 10, 2004
    1,863
    People have done it John, but it is a little bit more involved for Chorus owners. As well as the RNS-E unit, you will to strip out the entire centre of the dash and fit a double-DIN cage, plus either cut your existing climate control panel to fit it lower in the dash (using a dremel) or buy a new climate unit (expensive). You may also need some new buttons for ESP and the passenger airbag warning light.Agree with Steve though - the http://www.navplus.us is fantastic and full of information on the RNS-E. I used it extensively before my install.
  5. steve1975l
    steve1975l Member
    Jun 14, 2004
    595
  6. johnmv55
    johnmv55 Member
    Dec 5, 2004
    247
    Thanks Steve, shame he only does COD and has no paypal, I have contacted him anyway so I will see what happens, is all of that backing piece what is called the double din?
  7. johnmv55
    johnmv55 Member
    Dec 5, 2004
    247
    Thanks Ben, I have had a look there but didn't find any info regarding changing to a double din, I'll have another look later
  8. benw123
    benw123 Moderator
    Oct 10, 2004
    1,863
    Yep - if the climate panel was missing in those pictures, you'll have a big piece of plastic that bolts into the dash. This is what will hold the RNS-E in place.
    For me, as a Symphony II owner, the double-DIN cage, correct climate control and buttons are already in place, so only needed a harness and the stereo just swaps out.
