Chirping noise
sliced Mar 11, 2013
  1. sliced
    sliced Drive safe, stay alive.
    1,556
    334
    Hi guys,
    This morning my car is making a chirping noise when driving that's comming from the right front of the car, any ideas what it could be?
    Gets worse when turning right.
    Did spend all of yesterday launching the car, maybe this has done something?
    2006 Tdi a3bad 2.0 sportback
  2. NHN
    29,328
    1,708
    Chirping noise, maybe a bird you ran over is crying out, I'm stuck :tumble:
    Well could be a belt tbh, but try spraying some wd40 on the aux belt see if it goes.
    sliced likes this.
  3. sliced
    1,556
    334
    Looool poor bird never stood a chance :whistle2:
  4. sliced
    1,556
    334
    just WD40'd the belt and did some hard braking. Seems to have gone now :)
  5. sliced
    1,556
    334
    Probably did a few too many of these
  6. NHN
    29,328
    1,708
    1st thing in morning see if the noise comes back when cars idling on drive, if so, don't drive the car, leave running & again spray some wd40 on the belt & see if it goes, if so, then its either belt or tensioner.
  7. Boon
    Boon Active Member
    441
    59
    Or the alternator clutch pulley
  8. sliced
    1,556
    334
    Cheers will check if noise is still there in the morning!
  9. gary3306
    gary3306 Active Member VCDS Map User
    989
    40
    Or a little stone stuck between disc and backplate.
  10. Graham89
    Graham89 Derv Perv
    310
    I've got this same issue. Sprayed wd40 on the belt and it stopped. Not sure for long though. It's only doing it around 1000-1200 revs. Did you ever get yours fixed?
  11. sliced
    1,556
    334
    erm something similar happened before and it turned out to be warped brake discs?! got all the pads and discs replaced. Now again, a similar chipring noise.
    Sprayed some wd40 and did some harsh braking, so not sure what it was but the noise is now gone
  12. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    imho using an oil like WD40 not good as it attracts dirt to stick. Perhaps a dry silicone spray would be better.
  13. Graham89
    Graham89 Derv Perv
    310
    After some looking about on the web it seems to be an issue with the alternator pulley. I'll check that in a bit!
