chipping my B5 - dont want to mess with the ECU
andernalin_junk Nov 14, 2011
  1. andernalin_junk
    andernalin_junk New Member
    Hey
    I think this is my first post hare :whistle2:
    so its like that :
    My car - a 99 B5 with a full set up incl. w/m
    I have a sealth racing custom chip (thru a dealer in my country )
    but we havn't finish it yet ands regarless to that this is not my last one cuse soon i'll have a big turbo
    My ecu us 558E and we need to open the ecu to manually change chips on every version we do
    (I have a socket so we wont have to wels lt ) but i'm looking for a solution that we can do it
    thru the diagnostic plug
    anyone know how ? how did you make you own chip ?
    THX :blackrs4:
  2. aragorn
    18,436
    845
    The older M3.8.2 ECU's simply arent programmable via the diagnostic port.
    You can use an M3.8.3 ECU from an AGU engined A3 or Golf, which can be flashed using MPPS or other similar flashing tools.
  3. aragorn
    18,436
    845
    The other option is an EEPROM emulator, that plugs into the socket in place of the original chip, and is connected to a computer.
    This allows you to make many changes without having to write out a new chip until you've finished the mapping.
  4. andernalin_junk
    thanks !
    How can i match a golf or A3 ECU to my car ? what i need to do so that fits ?
    the eeporm is no good i think ... becuse the tuner is in the UK (stealth racing) and i'm in Israel
    another problem is that the originak chip is not re-writeble which means that we must use a new chip for every version (cost around 5poundsd)
  5. aragorn
    18,436
    845
    You can either remove the immo completely, or use vagtacho or similar to fetch the Secret Code and program the ECU.
    All of this is a moot point though, because MPPS is expensive (~2000 Euro), and completely uneconomical for one bloke wanting to flash his ECU. Its the type of tool a tuner would buy, as he'd be using it to map many cars. Given you dont have access to the tuner, you arent going to have access to MPPS.
    The later ME7 ECU's are flashable easily via the diagnostic port with cheap/free tools, but they will require you to convert the car to electronic throttle.
