Chipping 1.8T and dealer ignorance...
cheiliger Jul 28, 2003
  1. cheiliger
    cheiliger New Member
    Anyone know how I would go about chipping my 1.8T so that the dealer won't know when I take it into service? I don't want to void out the warranty. Thanks. /ubbthreads/images/graemlins/beerchug.gif
  2. DavidR
    DavidR Active Member
    1,296
    If the dealer is looking hard enough, they will find out but in my experience, none of the dealers I have used give a toss about a simple chip.
    Best bet is to get a serial port tune from the likes of APR or Revo. Arguably, APR is the tidier option as you can switch between programs (i.e. chipped, stock, 85ron, 98ron) from the cruise control whereas Revo uses a plug in module.
    All other chips require a new chip installed in the ECU box therefore are detectable if this is removed.
    I'm waiting for Starperformance.co.uk to get the APR serial hardware in then my S4 will be chipped with cruise added also.
  3. DavidR
    1,296
    Oh, I should probbably say that in case you didn't know, the serial port tuning leaves the ECU box untouched as the software is loaded onto the original chip via the diagnostic port.
  4. cheiliger
    Thanks.
    Can you reflash the ECU before taking it in for service?
    I'd like to be able to give the dealer a bone-stock car when they have to service it.
  5. DavidR
    1,296
    Not sure about all tuners, but with APR you can select the normal map from the cruise stalk and then lock it out (using a number of coded button presses) so to all intents it appears standard.
  6. RichA3Turbo
    RichA3Turbo ...Watching you! Moderator
    5,089
    I took my AmD chipped A3 to be serviced at Oxford Audi, and they didnt mention anything... I really dont think they care!
    Rich
