Chinese Clone = Can:Questionable, Will a genuine cable work?
madhoose Feb 28, 2014
  1. madhoose
    madhoose New Member
    17
    I was given a Chinese Clone for VCDS 12.12 however when plugged in it gives Can:Questionable and I can't access the Xenon lights section.
    My question is, I I pay £250/260 for a genuine cable will it work? Or Do i have a bigger issue that I need to fix before buying the cable.
    If I do buy from the seller on here or Gendan, if it still doesnt work can I get a refund?
  2. NHN
    29,354
    1,720
    I can assure you the genuine cable I sell works perfectly well, if it doesn't then its the cars diagnostics port/network at fault not the cable.
    dualmono21 and bearthebruce like this.
  3. madhoose
    madhoose New Member
    17
    Hi, That's the issue I'm having. I could shell out £250 and find out its the Diagnostic port, which means I then need to pay out to get that fixed before the cable can be used.
    I've emailed a few guys of the VCDS map and I'll see if they can test their genuine cable in the car.
  4. NHN
    29,354
    1,720
    Buying a Chinese counterfeit is your 1st mistake anyway fella, sorry to be blunt, but its a fact, waste of time & money, not a good basis to start diagnosing issues on the car, but you've done the right thing by asking a genuine vcds user to test your car 1st :)
  5. r15wne
    r15wne Member
    64
    10
    have had my genuine for a few years now works good free udates aswell.
    i recomend you contact nhn for genuine..
    bearthebruce and NHN like this.
  6. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,820
    197
    Even if you buy genuine, and the car doesnt work, are you saying you wouldnt want to fix the issue? My money is on the clone being useless. What car and can you connect to ANY modules?
    NHN likes this.
  7. NHN
    29,354
    1,720
    Couldn't agree more.
  8. madhoose
    madhoose New Member
    17
    Depends how much it costs to fix a diagnostic port if its goosed!
    I can access most of the controllers, and have pulled off a few fault codes of the HVAC system which i'm going to try and get the parts tomorrow.
    I can't access the xenon one, and I have a fault about the leveling showing on my dash.
  9. NHN
    29,354
    1,720
    Sorry but this forum doesn't support the use of illegal counterfeit cables & I for one cant help any further.
    Sandra and bearthebruce like this.
  10. @udi A3
    1,820
    197
    If you lost your keys today, You would be looking at 150-170 for a key to be made by usual means, ie gain entry, then program through the obd port.
    if your obd is goosed , I COULD still make you a key by stripping your dash clocks out, and id charge you double just for the hell of it knowing there is no other way.
    However, you could buy a genuine tool, fault find and fix it if there is actually a fault with the car at all, and the best bit, VCDS will allow you to reprogram a new key yourself. Now if you lost your key youd either have a spare already made by yourself, or Id do you a really good deal as you have half the tools to do the job yourself and im nice like that!
    ^^vcds sales pitch :D
    btw, these cables really seem to hold resale value when second hand, sometime even sell higher than new price !!
  11. L33AEX
    L33AEX Member VCDS Map User
    67
    When I brought my cable I did much research into the difference between a cloned cable to a genuine. Many people have had endless problems with their cloned cables also, some have said it has fried their ECU. I took it upon myself to purchase both. I paid £40 for the clone & £268 for the genuine thinking there wouldn't be much difference between the two - turns out I was wrong, the clone is cheaply made, and was no where near worth £40 I took one look and thought I'm not going to let a £40 cable fry my ECU - didn't even entertain the clone. When purchasing a genuine from NHN or another authorised distributor you gain full support on the software and usage of the product, with a clone you could end up with thousands of pounds of fault electrical bills. So do the right thing and buy a genuine one because there is no doubt you will get your money back on the secondhand market.
    NHN likes this.
  12. dieseldoos
    dieseldoos Active Member VCDS Map User
    206
    96
    Before I brought my genuine cable, I tried a clone. It "seemed" to work, but didnt actually do anything, or like yours, it wouldnt read a few modules. I brought the genuine cable and all is fine, so I would say the problem is the cable not your obd port, or a bigger issue.
    bearthebruce likes this.
  13. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    dont mess around with clone cables your liable to do more damage than good
    bite the bullet and buy genuine
  14. Wallm0nkey
    Wallm0nkey Member
    225
    Genuine all the way it just works! A decent independent garage round me charges roughly £40 for diagnostics so it doesn't take many trips to pay for a cable. You also have the option of helping other people for a small fee to recoup some costs which isn't really possible with a cheap untested cable.
  15. glenandem
    glenandem Active Member
    726
    i bought a clone and its done everything it needed for me, if i was going to be using one on a regular basis i'd buy a gen but the £30-£40 i spent on it has more than paid for itself clearing codes,checking parameters,coding things and even sorted my sisters golf with it when her car wasnt running right,was great using the logs etc!
    think theres so many clones round its hard to find a decent working one but they are out there but if your going to be using it more than a few times than buy a genuine!
