Chilled glove box
tuffy May 2, 2013
  1. rizzini7
    rizzini7 Active Member VCDS Map User
    974
    151
    43
    I have seen a couple of how to guides for fitting the pipe. But, not the coolbox and new light etc...
  2. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    The coolbox just slides into the glovebox - if anyone needs a "How To" for that then they should be ashamed of themselves.
    The new light - well there's only 1 place in front of the cool box where there's space for it, and looking at it tells you that it needs a rectangular hole, so you just cut a hole slightly too small (drill 4 holes in the corners and use a Dremel-style tool to cut the centre out) and then file it to a size where the light will fit but still grip. Then connect the original wires.
  3. rizzini7
    974
    151
    43
    Alright Dave. That does sound like something even I can manage :)
  4. rizzini7
    974
    151
    43
    Checked at Tps today and that's the same price I can get the parts with discount aswel. So not bad mate
    Off topic I also got 12 382 bulbs for the grand total of £2.45 all in wtf. Would of cost a fortune from halfrauds.
  5. GeoffDunk
    GeoffDunk Well-Known Member Team Panther Audi RS4 quattro Audi Avant Owner Group
    1,301
    390
    Anyone who wants a bit more detail and if it helps check here
  6. PetrolDave
    1,559
    85
    Note that the comment about there being 9 screws only applies to US market cars, on UK cars there are fewer (6 IIRC).
  7. Andy27168
    Andy27168 Member
    130
    9
    Thanks, thats good to know, it will save me looking for bolts that are,nt there, if the weather holds I will be doing this tomorrow, after I have gone to pick up my new RS4 alloy pedals, :) and order my rear footwell light brackets and lights.
  8. Andy27168
    Andy27168 Member
    130
    9
    Fitted mine today, and as Dave has said, there are only 6 bolts holding the glove box assembly in, three across the top, remove the CD changer and there is one there as well, and then two on the bottom edge.
    Drop the box down and unplug the glove box loom 12 pin plug and remove assembly from car.
    Find the knock out in the glove box for the A/C pipe, and cut away the insulation from the other side of it, it is already scored so relatively easy, cut out the knock out for the new pipe, fit the outer box, at this point you are meant to fit three small self tappers in the top edge of the outer box, but without removing the glove box door from the assembly, you cant get in there to drill, or use a screwdriver, so I decided not fit them as the outer box was a good fit anyway and once the inner box was in place with the vent in the back it would be held in securely.
    The outer cooler box just slid in though I did have to remove pin holding the glove box to the damper assembly to open it wide enough to get the inner and outer box in.
    The light fitting I neednt of bought, as it was exactly the same as my original light so I just relocated it and again as Dave said it can only go in one area and 5 minutes with a Dremel and it was fitted.
    The vent pipe was straight forward, just pull out the rubber bung and slot it in and twist.
    Refit the box after plugging the loom back in, the new pipe lined up exactly, I loosely fitted a couple of screws on the top edge, and screwed the vent on tight in the back of the glove box, refitted all the bolts and CD Changer.
    Overall very easy to do and works a treat. Very pleased with the overall result, one more mod off of the list! :)
    sidibear likes this.
  9. rizzini7
    974
    151
    43
    Good work mate. Just trying to convince the misses I need one :)
  10. PetrolDave
    1,559
    85
    What I said :happy:
    It's great in the Summer to be able to grab a cold bottle of water, or can of WHY.
  11. rizzini7
    974
    151
    43
    Well that's me in trouble, just won a glovebox on eBay for £92 posted. On thing is it doesn't have the door or light. I assume I can just swap the door over from mine?
  12. rizzini7
    974
    151
    43
    Damn it, now I'm not sure if its for left hand drive. And didn't state what side it's for. Listing says outside uk even though I search for uk only.
    Well looks as if I purchased the wrong one. Now trying to contact seller to see if I can cancel. Doh
