Checking for a faulty DV on 2.0T FSI
niggtv Sep 6, 2013
  1. niggtv
    niggtv Member
    81
    There's a lot on the Mk5 Golf GTI forum about the DV failing over time, reducing boost. Would this always throw up an engine management light or error code, or is it worth checking? No problem with the running of my car - just wondering!
  2. RobinA3
    RobinA3 Well-Known Member
    1,827
    47
    Yes you will know if you had the problem as you wouldn't have any boost and you'd notice the massive loss in engine performance.
  3. RobinA3
    1,827
    47
    It will also throw up an engine check light but to demanded boost not being met.
  4. Aidy06
    Aidy06 Member VCDS Map User
    412
    19
    Mine didn't throw up any warning lights at all, I just thought the car didn't feel all that it should. I guess when I got beat off the lights by a TDI that confirmed my suspicions, ordered a rev D DV and took off my old one to find it was ripped to shreds. New DV fitted and car feels like a different machine
  5. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,218
    2,033
    Only four torx to remove along with the electrical connector to check,Its on my list as I am not getting boost reading I think it should have.
  6. MrLapou
    MrLapou Well-Known Member
    1,233
    121
    May be I carry out doing it wrong way, but found compared the MK5 GTI , on the Audi 2.0T it's harder to get to the hex head bolts.. what a pain!!!!
  7. hades-
    9,481
    646
    not always very rare to have a light on for the DV
  8. voorhees
    16,218
    2,033
    Yes you could be,undo the bracket torx first then you can jiggle it to undo the others which hold the DV,2.0T is the same enjin (waits for someone to say a nut/gasket is different)
