Hi guys does any1 know this fault code means????
Does it need reseting???????
Ok was just a stab in the dark :-/Shouldn't need to rest anything when you change the clutch switch.
Mmmmmmm I have cleared them and yes the still thereYou do need to clear the codes... they don't clear themselves... if it comes back then you still have 'a' problem but... that not a fault code normally associated with the clutch switch iirc....
Today's date is February 28th 2015. Just thought I'd clear that upBTW the switch is a fit once part so you do need to fit it correctly or it won't work.
