Markeyboy
Fan of the R-Tech!
i keep getting this fault code pop up every time i run a scan with vagcom
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
P1297 - 35-10 - - - Intermittent
iv checked the system for damaged hoses, cant find any, dv checked out fine (007p)
the car is on a std map, fmic, tip and simplified pcv with catch tank
iv taken some logs of actual and specificied boost, as iv been told this is where a boost leek can be identified
heres my results
blue is specified, red is actual
does it look like there is a problem?
heres my results
