Check DPF Soot Levels in VCDS?
Dannykn9 Nov 10, 2011
  1. Dannykn9
    Dannykn9 "Cruise My Ride" VCDS Map User
    1,123
    56
    Quick one guys, how do I check my actual and calculated soot levels using VCDS? Tried searching with no joy!
    I know it is under engine module but not sure how to actually find it? I believe it also tells you mins/hrs since last regen.
    All help appreciated.
    Danny
  2. ashaudia3
    ashaudia3 Member
    52
  3. Dannykn9
    1,123
    56
    Cheers for that fella, yeah I checked that but the percentage was under lamba reading, is this correct?
    Sure I have seen somewhere that it tells you actual soot level and calculated soot level? Or am I going crazy!!
    Also do you know how to adapt the new DPF sensor?
  4. Rhyso
    Rhyso Well-Known Member
    1,459
    295
    On my 57 plate A3 170 its under block 70 and 75 and yes lambda % is the correct term; well on mine anyway. i think the terminology changes based upon year and the engine fitted?
  5. timmythechef
    timmythechef Starin' Through My Rear View
    263
    Hows the posh golf going rhys/
  6. Dannykn9
    1,123
    56
    Cheers Rhyso, just need to find out how to adapt the new sensor before I install.
    Cheers fella
  7. Rhyso
    1,459
    295
    Pushing out 200bhp and racking up the miles lately. How's yours running? You still getting silly MPG??
    Would have thought it would be plug and play?
  8. timmythechef
    263
    Yeah I can do, till I found how much its pulls after 80mph with the new turbo, its like a different car, but I can get silly MPG if i want, shall be visiting Kris soon I think.
  9. paultaylor
    paultaylor Member
    294
    Saturday,11,May,2013,20:38:43:10074
    VCDS Version: Beta 11.2.0
    Data version: 20110305
    Address 01: Engine (03G 906 018 DN)
    20:38:23 Group 070
    00000000 Bin. Bits
    0.0 s Time
    0.0 (no units)
    0.0 (no units)
    20:38:23 Group 075
    132.6°C Temperature
    95.6°C Temperature
    11.5 % Lambda
    58.5°C Temperature
    Just got the above results, was expecting to see a much higher Lambda % as the fuel consumption is poor given it's 70% motorway, only getting about 430 miles for a full tank(07 2.0tdi 170 DSG S line sport back
    Part of me is hoping that replacing the G450 DPF sensor will help Mpg?
    Address 01: Engine Labels: Redir Fail!
    Part No SW: 03G 906 018 DN HW: 03G 906 018 DN
    Component: R4 2.0l PPD1.2 1247
    Revision: --H42--- Serial number: AUX7Z0G4FN3049
    Coding: 0000078
    Shop #: WSC 06314 000 00000
    VCID: 74E3D8E36C7B
    2 Faults Found:
    001139 - Exhaust Pressure Sensor 1 (G450): Signal too High
    P0473 - 006 - Short to Plus - Intermittent - MIL ON
    Freeze Frame:
    Fault Status: 10100001
    Fault Priority: 1
    Fault Frequency: 38
    Reset counter: 40
    Mileage: 76880 km
    Time Indication: 0
    Date: 2013.05.04
    Time: 11:24:32
    Freeze Frame:
    RPM: 0 /min
    Torque: 0.0 Nm
    Speed: 64.0 km/h
    Voltage: 14.01 V
    Mileage: 140 km
    Text: 512 C
    Pressure: 1874.4 mbar
    001137 - Exhaust Pressure Sensor 1 (G450): Implausible Signal
    P0471 - 006 - Short to Plus - Intermittent
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 35
    Mileage: 0 km
    Time Indication: 0
    Freeze Frame:
    RPM: 0 /min
    Torque: 144.0 Nm
    Speed: 0.0 km/h
    Pressure: 85.2 mbar
    Text: 232 C
    Temperature: 39.0°C
    Text: -42 mbar
    Readiness: N/A
    any help would be great
    I
  10. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Update your VCDS to the newest version and rescan.
    Maybe start a new thread too? ;)
