Cheapest way to impove looks/performance?
A3matt Apr 4, 2010
  1. cooltempo
    cooltempo Heavy DERV clatter
    95
    cheers mate! Audi in stoke have checked my chassis number etc and seem to think the standard soul black fabric FCA will fit, £155 all in, with template and bracket etc..
    and thanks for the wheel suggestion, they are definitely nicer than stock. I'll keep my eyes peeled!
    Mo
  2. paddy
    paddy Audi=No fault code, no idea Team Ibis Audi S3 Black Edition DSG
    5,267
    162
    Good advert for parking sensors....
  3. cooltempo
    95
    I knew I'd get some stick for this ;)
  4. Lewbo
    Lewbo Well-Known Member
    1,266
    105
    i seen that s3 on bluecycle was going pretty cheap i thought when i saw it. the s3 is an easy repair, wouldnt of minded bying it myself but insurance is way too much as im only 19 so sticking with the s line for now. good luck fixing the a3 pal, going to need it. just hope you dont run into other problems like i did and have to spend more than planned. there is alot of work trust me.
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    well pie eyed mate, im ony 800 for the insurance, benifits of being 21 :)
  6. rickyquicky
    rickyquicky Member
    342
    VIC check is primarily to confirm the vehicles identity, ie not ringed/doubled up etc.
    I didnt think they looked at the repairs too much, if they do its pretty easy to conceal shoddy work, I would never trust a VIC test, ive seen plenty of shoddy repairs on cars that have gone through the test.
    Good luck with the project anyway, got the car for a decent price and £1000-1500 tops should see you done, if you know painters, panel beaters etc then your laughing.
    Only thing that would worry me is engine damage, has it gone that far back?
    As for cheap improvements, performance wise theres not a lot you can probably do, doubt a remap would be worth it. Just facelift parts and im sure when your getting your bits out the breakers there might be some nice bits from better models you can get cheap eg leathers etc.
  7. PH1L
    PH1L Gievf Buckets
    3,851
    40
    engine is far back anyway witht eh 1.6 just looking at new radiator and ac rad if it has ac
  8. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    Bet your wife was glad she wasnt driving it lol...... it happens I guess, good repair though!
  9. ghouseman
    ghouseman Gazza
    92
    If you dont get it on a jig you'll be crabbing down the road. I've seen cars with less damage going sideways. If you're gonna do it. Do it right, good luck mate.
  10. rickyquicky
    rickyquicky Member
    342
    A jig is ideal, but wouldnt go as far to say as it will be 'crabbing down the road' without one.
    It looks like the wheel has moved but after repair a proper 4 wheel geometry measurement will get it 95% there without a jig and measuring it all up. Biggest problem without jig is getting panels to line up IMO.
    If he replaces all the subframe and wishbones etc, im sure it will be ok anyway, it doesnt look hard enough to have damaged chassis where the subframe mounts.
  11. A3matt
    A3matt Member
    37
    here is another picture from the drivers side.....
  12. mdre83
    mdre83 Member
    634
    You have your work cut out there mate, good luck with it though hope it works out :icon_thumright:
    Keep us updated...
  13. phil76
    phil76 Active Member
    572
    40
    I would say £1000 above for parts alone,you would be lucky to get everything 2nd hand,is the engine ok does it run? but panel there is bonnet,frt panel,rads,headlamps,bumper reinforcer,brackets,frt bumper,airbags,i would say suspension,wings,is that the fuse box hung down,has the screen gone?,i work in a bodyshop myself and yeah things repair suprisingly but i would have stripped the car a bit more before i made the purchase because as it is here hidden work is sometimes the killer and if thats been wrote off without been stripped there must be some heavy damage,we have to normally strip them if looking anywhere near the valuation and as that hasnt been that would worry me,Not saying it cant be done or been negative i hope things do work out ok with it
