cheap brake upgrade 312mm
tangerinedream Oct 10, 2011
  1. tangerinedream
    tangerinedream Member
    249
    hi all im from the b5 section, i have recently aquired a pair of 312mm carriers and calipers ,unfortunatly i bought them in a bit of a hurry and didnt realise they fit b6 uprights and not mine :( im really just after what i paid which was £100 posted) these would be ideal for any of you guys currently running either 280mm or 288mm front discs.
    make for a really nice upgrade if interested pleae just give us a pm
    cheers all
    shane
  2. CMD
    CMD Pointing Forward's!!!!!!!!!
    3,015
    17
    Whats the condition , any pics
  3. tangerinedream
    249
    they are very clean, will post pic tonight
  4. CMD
    3,015
    17
    Sweet i can drop these on to my mk4 golf
  5. Kingfisher
    Kingfisher Active Member
    304
    60
    Tangerinedream
    You should be able to use these with your current caliper.... even saves bleeding the brakes !
    I've been running this for about 7-8 years on a 1.8T quattro Sport. It came with 288mms front discs.
    Unbolted carrier, dismantle current caliper/carrier, re-assemble 312 carrier to existing caliper, fit 312 disc, bolt up 'new' carrier/caliper, insert pads.....
    Not as good as a proper 'big brake' kit but a worthwhile small improvement imho
  6. aragorn
    18,612
    872
    kingfisher: he has mk5 golf calipers, which use a wider spacing to what the B5 uses, hence why he cant just do what you've said!
    B5 uprights only work with Mk4 golf/Mk1 TT/8L S3 carriers.
  7. Kingfisher
    304
    60
    Ah ! Sorry Tangerinedream --forget what I said then !!
    CMD looks like its GO !
  8. CMD
    3,015
    17
    Yep the 312 setup is what all the MK4 lot are doing
  9. scott b
    scott b Active Member VCDS Map User
    1,254
    if CMD changes his mind im going to be taking the b5 321mm set up of my A4 B6 (swap?)
  10. gavsman
    gavsman Member
    379
    It sounds like Tangerinedream has got a set of ATE caliper's and carriers from an A4 B6 3.0 petrol, Tangerinedream can you clarify this?
  11. tangerinedream
    249
    this is spot on :)
