newbster
just finished changing alternators on my TDI, but should apply to most A3/S3
oem fitting is valeo or bosch, interchangeable, the bosch is a better unit as its a lot easier to change the bearings/brushes etc
bosch have been making the same basic unit for years, and are fitted across the whole range of engines
looking at the dimensions for one from a 2012 Passat tdi, it looked the same, but a lot higher current rating, I chose this one as it was on ebay when I was looking for a new unit
I took a punt on it as it was only £35, it did fit but the connection for the regulator was different, but being a bosch, a new regulator from an earlier model is a direct fit and has the correct connector.
so for about £50, I got a virtually new bosch 130A alternator, saving over £100 on the best price I've seen for these.
here's a picture of it in its new home, those of an OCD nature should not look at the rest of the engine bay
