Chassis number cover
richh Jun 20, 2006
  1. richh
    richh New Member
    27
    Can the perspex cover over the chassis number on the bulkhead be replaced. Mine has completely disintegrated and at a cursory first look it seems to be attached fairly well (what's left of it) to the surround.
    Not a very excitng question, but any help appreciated.
    Thanks.
    R.
  2. S3_MCD
    S3_MCD Member
    389
    Mine also .... popping into dealer soon so will ask (they are pretty clued up so expect a reasonable answer).
  3. jcs356
    jcs356 Brum brum
    2,723
    64
    I suspect you will have to replace the entire plastic scuttle panel. £35 from memory?
  4. concoursneil
    concoursneil Member
    328
    Def scuttle panel replacement , the new one will do just the same over time.
    Better off trying to trim it off really neatly and possibly cutting a proper bit of thin perspex and fitting it in the same place.
  5. richh
    richh New Member
    27
    Thanks for the ideas, £35 isn't too bad for the whole panel, but a bit steep for a 4" bit of perspex. Might try the Blue Peter method first.
    R
  6. Just replaced mine as well, the clear window is def. bonded to the scuttle panel.
