Changing Thermostat on AMK, driving me insane!!!
beanoir Aug 18, 2011
  1. beanoir
    beanoir Large Member
    2,171
    31
    Guys,
    I'm at the end of my tether trying to access the bottom bolt on the t'stat housing, how on earth are you supposed to do it?
    Any hints or tips would be greatly appreciated before I throw my toys out of the pram!!
    Cheers!
  2. Sam_
    Sam_ Down under
    3,038
    480
    A small 1/4" ratchet was my saviour. Without that it's pretty hard.
  3. SiGainey
    SiGainey Member
    506
    9
    So so easy. Where in the country are you?
    Undo the battery negative terminal, remove the main wire going to the alternator, get a knuckle joints on a 1/4 ratchet and it's 15, 20 minutes work...
  4. danger S3
    danger S3 Member
    372
    i used a universal joint on my wee 1/4" ratchet as well. its a pain to get to but it is possible
  5. Sam_
    Sam_ Down under
    3,038
    480
    I didn't remove the alternator wire. Possible without doing that...
  6. badger5
    9,505
    2,003
    you moved the alternator?
    move it and its accessible
  7. beanoir
    2,171
    31
    Guys thank you for the assistance. 1/4" set was the deal clincher, managed to do it, so it's now all done. Took her for a spin for 30 mins and she heats up right bang on 90C and the mpg should be a bit better now too.
    Thanks again!! :)
  8. Prawn
    11,535
    3,475
    I need to do the stat on the track car too, but I've been putting it off for weeks!
    Since i realised I needed to do the stat, I've done the following:
    Fitted 12 point roll cage
    Fitted new seats
    refitted gearbox and clutch
    changed driveshafts
    Painted interior and roll cage
    But I'm still putting off changing the stat, because it's a hateful job!
  9. beanoir
    2,171
    31
    it is a right fiddly job, but I reckon it wouldn't be so bad a second time around...not that i'm hoping to have to do it anytime soon!!
  10. Sam_
    Sam_ Down under
    3,038
    480
    Probably a bit easier with the inlet off which, in itself, isn't too bad.
