Changing the oil
mm707 Jul 18, 2011
  1. mm707
    mm707 Member
    284
    Hi All,
    Think I might change the oil myself on 2007 2.0 tdi.
    Anyone know if I have to remove that whole plastic protection piece under the sump to get access to the sump nut ? Looks a bit awkward to do on the drive with a jack and a couple of axle stands :)
  2. rowdyboy
    rowdyboy Member
    804
    19
    You have to undo all the quick release fasteners and take the cover off. I invested in a Pella pump, it sucks the oil through the dipstick hole, it saves loads of hassle.
  3. kev1000
    kev1000 Member
    209
    do it, it's easy and afterwards you'll feel better for doing it yourself.
    a little tip for you : if the oil filter is a bit too tight to open by hand and you don't have a special tool for opening it, wrap a piece of sandpaper around filter ( grit against filter) and twist.
    always works for me anyway.
  4. mm707
    mm707 Member
    284
    Many thanks - I'll investigate the pella pump option too.
    Car has only done 4k in the last 12 months ( last oil change ) - would you guys still change the oil ?
  5. mm707
    mm707 Member
    284
    stupid question but ( when facing the front of the car ) where is the sump plug ? , struggling to get tunder the car, not enough room
    Wish I'd bought the pella pump :)
  6. mm707
    mm707 Member
    284
    Also - do I remove two plastic trays from underneath or just the one nearest the back ?
  7. kev1000
    kev1000 Member
    209
    Front tray will do.
    Can't remember which side the sump nut is. feel around the sump for it.
    It's Probably a 14mm or a 17mm.
