changing the dash lights on A4
shaggy Apr 23, 2008
  1. shaggy
    shaggy New Member
    Hi all,
    some of my dashbulb lights are playing up, especially the ones which light up the headlight switch on/off dial.
    Do I need a special tool to open up the dial so I can get at the bulbs? The whole thing seems very easy to scratch so i want to be careful i dont mess this up.
    Are there any insyructions I can find anywhere?
  2. chris_20
    chris_20 Member
    707
    same here, mine need replacing in the on-off headlight switch. will be interested to see other peoples replies
  3. jegs
    jegs New Member
    Hi
    The headlight switch is a complete unit which you twist and pull out so you get a new unit from your local dealer. Will try and find a diagram later to show how to remove the switch
    HTH
  4. jase0851
    jase0851 Member
    789
    turn the switch to the left about 10 degrees push it in then turn it to the right 90 degrees
    the bit that turns the lights on
