CHANGING steering wheel
rasA4 Jul 29, 2006
  1. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
    hi all considering changing my B5 4 spoke to a B5 3 spoke got some questions
    1. how easy is this to do?
    2. what tools are required i remember some else talking about they have hex type screws on the back?
    3. are they the same head size as the 4 spoke?
    4. what type of tool is required to take the main nut off?
    5. will the car have any problems recognising the 3 spoke airbag?
    SORRY so may questions
    any tips and advice much appreciated .
  2. dunk
    dunk Member
    770
    they fit easily and the wheel is the same size (diameter) and depth
    you need a torx tool to undo the airbag screws and a large spline tool to undo the central wheel nut (got mine from the local car factor, not difficult to get)
    the airbag will be recognised but you may throw an airbag error code with it disconnected and possibly need vagcom to reset it.
  3. rasA4
    3,287
    119
    thanks dunk
    do you know what size torx need for the airbag and wheel?
    anyone?
  4. rasA4
    3,287
    119
    surely someone has changed from 4 spoke to 3 spoke?
  5. tracer
    tracer '96 a4 1.8 se
    266
    just removed my steering wheel, in answer to some of your questions
    4mm allen key did the job for me
    24mm socket, 1/2" ratchet with small extension fitted
    hope this is of some help
  6. rasA4
    3,287
    119
    gr8 thanks!!!! what is yours a 4 or 3 spoke? ive been told they have different size allen keys?
    cheers
    p.s did you change your from 4 to 3 spoke? did u have any trouble with the
    air bag light?
  7. AndyMac
    9,832
    45
    As long as you don't switch the ignition on with the airbag disconnected you shouldn't throw an airbag light error. I had to take my steering wheel off to get to the ignition barrel and got no errors afterwards.
    Disconnect the earth strap on the battery to be double sure but make sure you have the stereo code.
  8. tracer
    266
    mine's a four spoke, have taken it off to get to immobiliser wiring.
    not sure on 3 spoke, sorry.
    same as andymac i have disconnected the earth strap. going by haynes manual it says once everything is reassembled to switch iginition on first then reconnect battery. guess this just means yer nowhere near the airbag when power is first applied!?
  9. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    ras, yours has a splined sterring wheel bolt, and you can get an error code without doing anything with the ignition. (I know I just got one!)
    Don't use allen keys for your airbag bolts, if you strip them you have a lot of ball ache to get them off. A torx key set is pennies, drilling out unreachable bolt heads in the back of an airbag is not!
    I have a 3 spoke wheel I am relisting on Ebay cos some tw@t still hasn't paid me for it. its off a 99 1.8t sport, 3 spoke leather, recently refurb'd with liquid leather, smells and feels new, should be able to pick up an airbag easy enough, any 3 spoke bag. PM me if interested
  10. Donald_MacIver
    Donald_MacIver Member
    214
    I have recently changed my SE spec 4 spoke steering wheel for a quattro/sport spec 3 spoke. With my car being a 1997, and yours a 2000, i am not sure they will be exactly the same.
    To be brief, you need to disconnect the negative earth cable from the battery. You then need a torx type key (similar shape to an allen key), to get the airbag retaining bolts undone. You then disconnect the airbag wiring, under the cowling. You then carefully remove the airbag. There is then a 24mm retaining nut holding the steering wheel onto the column. A rachet will do the trick here. Haynes recommend the nut to be renewed before refitting, but this is not necessary. And you guessed it, refitting is a reversal of removal.
    There is one very important point though, make sure you have the ignition key in the on possition before you reconnect the battery negative terminal, to avoid the airbag warning light to stay on. Hope this helps.
  11. jcb
    4,132
    13
    well each to his own but I specifically didn't disconnect the battery.
    airbags don't go off on parked cars.
    leave you ignition off, it won't go off (unless you try to remove it with a shotgun).
  12. rasA4
    3,287
    119
  13. Donald_MacIver
    214
  14. AndyMac
    9,832
    45
    Just get a set of driver bits from Wickes - £3.95, includes Torx, Allen and security star bits.
  15. 205man
    205man Active Member
    1,072
    14
    if you have a pound land in your town try there....i got a set from exactly like that set on ebay for a......pound lol
    alan
  16. rasA4
    3,287
    119
    thanks anymac and 205man ill try these
  17. jcb
    4,132
    13
    did you find a wheel in the end?
  18. rasA4
    3,287
    119
    Thanx a lot AndyMac what a bargain well made wickes tool, id never would have thought they would sell these i paid 3.49 for a 8 piece torx hand held tool not the same as you have but just what i require.
  19. rasA4
    3,287
    119
    yes thank you
  20. mykaloon
    mykaloon Member
    45
    I'm still on the lookout for a 4 spoke leather wheel as fitted to se spec models to suit my 98 A4 Avant. Anyone got one of these spare. I don't need the airbag as I'm looking to replace my non-leather 4 spoke wheel (assuming that the airbag will be the same).
    I've been on the lookout on ebay for a bit but it only seems to be the sport 3 spokes which come up, then I need a different airbag and then it's getting into silly money...let me know if there's one out there.
    Mykaloon
  21. rasA4
    3,287
    119
    you will have to be patient they do come up if i see one ill PM you.
    have you tried your local breakers?
  22. jase0851
    jase0851 Member
    789
    ras i changed from a 4 spoke b5 to a 3 spoke b6 s4 steering wheel u can see the wheel on my interior post
  23. rasA4
    3,287
    119
    thanks jase i have seen your post already your motor is the bizzo.
  24. rasA4
    3,287
    119
    all fitted ok here the answers to my questions just incase anyone else is interested.
    thanks for all your input
  25. AndyMac
    9,832
    45
    Hey Jase when you've finished you will have ended up building a complete B6 from a B5!
  26. jase0851
    jase0851 Member
    789
    ya probs right andy i just fancied doin summat a little bit different and got carried away lol
  27. jcb
    4,132
    13
    someone won my 3 spoke leather A4 sport wheel and didn't pay up, pm me for details if anyone is interested!
  28. rasA4
    3,287
    119
    report them to ebay i remember u saying this before did u relist?
  29. cocain
    cocain RAA RAA like a dungeon dragon!
    214
    you have pm
  30. jcb
    4,132
    13
    this is the 3rd time i have sold it
    1) didn't pay because he missed out on the airbag - made him pay me the list and final valuation price
    2) didn't pay because he was in ireland and couldn't sort out paypal or bank drafts
    3) bloke with a "private" feedback status just hasn't responded.
    i have sold a phone recently, same deal, 3 scammers looking for shipping before payment.
    seriously p1ssed of with ebay and paypal
    anyway - open to offers, needs to go - it is just the wheel btw
