Changing Spark Plugs Audi A3 Turbo?
selector007 May 12, 2008
  1. selector007
    selector007 Member
    47
    I have a 1.8T quattro 2000 70,000 miles, the last time i got it serviced i took down to my local audi dealer and oh yes they serviced it but they also took all my money!! So i thought this time i would service it myself!
    So i changed the oil, oil filter, air filter and then when i got the plastic cover off to get to the spark plugs i was a bit bemused and stuck!!? Has anyone managed to change their spark plugs themelves? (As the last time i changed some spark plugs was on my pug 205 which had HT leads!!)
    Is it worth trying to do them, i have the spark plug wrench? Anyone got any guidelines?!
  2. HTC
    HTC Active Member
    3,428
    9
    Have a read of this and see how you feel about the task.
    Just to add, where is says to tighten the plugs "hard".....don't. You need to tighten them, but don't hang off them. Torque setting is 30Nm. Also start screwing them in with an extension by hand, so you know they are in staright, then finish off with the rachet.
  3. Wingnut Express
    Wingnut Express Audi sponsored by Mastercard
    124
    I changed the plugs on my S3 Saturday and it was pretty easy.
    The only problem I came across was the rubber grommet was mising from the inside of my spark plug socket, so I placed a bit of insulating tape on the inside & over to the outside of the socket so that the plugs would come out.
    Maybe I should buy some newer tools instead of doing an A-Team job on it :laugh:.....
  4. buckas
    buckas Member
    749
  5. selector007
    selector007 Member
    47
    Thanks Guys will try it on Saturday and hope for the best! FYI I got Bosch platinum spark plugs.
  6. themanthatcan
    themanthatcan Member VCDS Map User
    661
    I fitted Bosch Super 4s to my S3 a few weeks ago and it was a nice easy job. Bought myself a long 10mm spark plug wrench from Halfords for £4.99 and it took probably 20 mins in total. :thumbsup:
  7. buckas
    buckas Member
    749
    what's the product code of the super 4's? don't tend to trust halfords recommendations as they've been wrong before
    what does he use the allen key for?
  8. abdus
    abdus Top Gear VCDS Map User
    1,827
    unbolt igintion coils
  9. themanthatcan
    661
  10. When you serviced it yourself how do you reset the service light?
  11. nealb
    nealb Member
    85
  12. tony_a3
    tony_a3 Member
    76
    13
    Hi there my audi a3 is from 2001 done 200.000 I want to change the spark plugs but not sure what's the best ones any ideas ??
  13. basil brush
    basil brush Active Member
    538
    176
    43
    Like this
  14. <tuffty/>
    21,873
    4,201
    NGK PFR6Q or NGK BKR6EIX
    fanta likes this.
  15. ayfreetee
    ayfreetee Well-Known Member
    1,464
    290
    I fitted Denzo plugs a wile ago, they are cheap and work very well, check out carparts4less or eBay for good prices.
  16. <tuffty/>
    21,873
    4,201
    Sorry mate but Denso plugs suck monkey balls... They have a habit of dropping the ceramic off the plug which makes a bit of an expensive mess of your engine
  17. ayfreetee
    1,464
    290
    Used them for many years and never had that happen.
  18. <tuffty/>
    21,873
    4,201
    Lets hope it still doesn't... wouldn't touch denso plugs with a barge pole myself...
  19. ayfreetee
    1,464
    290
    You've put the frigheners on me now, I'm going to be paranoid until I change them.
    fanta likes this.
