Changing Rocker Cover Gasket - 2.0 TDI
Wrath Jan 21, 2014
  1. Wrath
    Wrath Well-Known Member
    1,196
    42
    Just had a call from the dealers as my car is in for a service and MOT. They've mentioned there was a small bit of oil coming from the rocker cover, nothing to worry about but they had to mention it. They said it's likely to be the gasket needs replacing but I should check it in a few months.
    Have any of you changed the gasket? If so, is it easy? Any special tools? Any tips? What was the part number and how much was it?
    Car is a BLB 2.0 TDI.
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,939
    735
    It's either a hex bold or torx head screwdriver required, but cannot remember. Simple enough job. Part number for the gasket is 03G103483B around £20.
  3. Wrath
    1,196
    42
    Cheers for the part number. Makes more sense doing it now. I asked them how much they'd charge and they said £120!
  4. SinghB7
    SinghB7 Active Member
    525
    68
    Its really easy, theres about 10-12 torx bolts you remove and a pipe on top of the cover.
    When putting the rocker cover back on make sure you don't over tighten the bolts or you will be shafted.
    If you can get hold of autodata find out the torque figures, when I done my glow plugs I think autodata said the bolts were 10Nm and tighten them going from the inside out to the corners.
  5. ukdan
    ukdan Member
    72
    You also need to put a little bit of sealer on the corners of where the gasket goes round the injector wiring loom.
