Changing Rear Brake Pads 2006 A6..........
A6Ian Jan 27, 2010
  1. A6Ian
    A6Ian New Member
    25
    Is there a twist with these? Just asking as it has an electronic handbrake.
    Do you need special tooling?
  2. jwhat
    jwhat Member VCDS Map User
    541
    I don't know about the A6 but on the passats you need to use VCDS to do something, it might be the same?
  3. Cockney Boy
    Cockney Boy Member
    483
    Changing the pads on an A6 with electronic handbrake, requires VCDS
    Open Rear Parking Brake
    Prerequisites:
    • Connect a battery charger.
    • Cycle the Parking Brake ON, then OFF first.
    [Select]
    [53 - Parking Brake]
    [Basic Settings - 04]
    Group 007
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    The brake calipers will then open, allowing the pads to be changed.
    [Done, Go Back]
    [Close Controller, Go Back - 06]
    It is normal for the LED in the parking brake switch and the warning lamp in the instrument cluster to blink rapidly at this point.
