Changing rear arms and arb
Sam_ Oct 26, 2012
  1. Sam_
    Sam_ Down under
    3,038
    480
    I'm going to attempt to fit 4 adjustable rear arms tomorrow and the ARB. Anything I should look out for? ARB appears to be an exhaust and heat shield off job, then pretty straight forward. Arms a like for like replacement, one at a time?
    I'm going to match the length of the arms to the OEM ones and maybe adjust some of the camber out a touch before I get a proper alignment done.
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    You just need to drop the exhaust from the body, no need to remove, just undo the hanger plates and it will drop...
  3. jojo
    28,998
    3,652
    Ideally, you need a big box or a trolley jack of some sort to support the exhaust backbox, or all the weight will be on the center exhaust hanger. Consider I've not done it before, I manage to do it on my own on axle stands outside my house, it's not a difficult job.
    The lower arms are straight forward also, just make not of where the xenon height adjuster arm bolts to and mark in the same place on the replacement arms, the top ones are a bit more trickier, you need to undo the rear subframe bolts to get them off, s3dave has done a how to guide elsewhere on the forum to swop those over.
  4. Sam_
    Sam_ Down under
    3,038
    480
    Ah, sounds like a job for another day then if I have to remove the subframe bolts. I have the headlight adjuster adapter from Gruvenparts so should be ok there. I read that you need to fit new bolts too? Is that right?
  5. jojo
    28,998
    3,652
    It's just two bolts from the subframe to allow clearance for the bolts from the inner tie arms to be removed. I would prefer to do this job on a ramp than axle stands personally. If the original bolts are ok, I see no reason why you need new ones?
    http://www.audi-sport.net/vb/a3-s3-...placement-too-adjustable-camber-arms-how.html
  6. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    It's not to bad to do the tie arms mate done mine in the dark last night with a lantern ;)
  7. jojo
    28,998
    3,652
    Did you change the top or bottom ones Stace?
  8. jojo
    28,998
    3,652
  9. Sam_
    Sam_ Down under
    3,038
    480
    Cool, maybe next weekend - the mrs will kill me if I work on the car on her day off :(
  10. Sam_
    Sam_ Down under
    3,038
    480
    Oh I just saw on one of the forums on my google mission that the bolts are one use. Personally I've only ever replaced head bolts...
  11. StaceyS3
    2,505
    502
    Top ones but have had bottoms off before and didn't find them much different
