CHANGING OUTER CV BOOT ON A 2004 AUDI A3 8P
RGC Jun 7, 2010
  1. RGC
    RGC I void warranties"!
    149
    Hi all i am going to change my split boot on my a3 in a few days and was wondering if any one has any tips and tricks to getting the hub off the CV joint, I was looking at it today and it looks like the easy way will be un-doing the lower bolts and pulling the hub from the joint. I have had 2 new bearings fitted last year so the hub bolt should not be that seized on (fingers crossed)
    also which way are the hub bolts threaded? right to tighten left to loosen? or opposite?
    i will be using a stretch CV boot with a cone to allow it to be slid over the CV joint thus not having to remove it from the shaft
    thanks guys ;)
  2. edition
    edition Active Member
    1,426
    Audi did mine for £120 fitted so it can't be much of a job on them!
    I was going to do it but I hate that grease!!
  3. ste
    ste reverse gear
    121
    hi, a genuine audi boot kit is quite cheap and easy to fit. the hub nuts are normal thread ie, loosen anti clockwise and tighten clockwise.
    some of those stretch over boots are rubbish
  4. RGC
    149
    whats the best way at getting at the cv joint? do i have to drop the whole hub and suspension out just to access it?
  5. bambam
    bambam Member
    123
  6. RGC
    149
    good for stripping the suspension but I'm not doing that :) don't see any talk of a CV joint in that link :(
    thanks tho :D
  7. mcconnot
    mcconnot Member
    75
    Im going to be doing the same CV boot replacement soon so any help would be great!
  8. bambam
    bambam Member
    123
    A quick google search reveals...
    Ripped from another forum
    You'll need to undo the drive-shaft bolt, jack up the car, remove the lower ball-joint, then pull the hub assembly away from the drive-shaft. Once you've done that, you can then undo the inner CV joint bolts, which are attached with Torx bolts.
    Make sure you've got all the correct torque settings for when you put everything back together. And you'll need to get your tracking re-set after you've put it all back together.
    http://www.tyresmoke.net/forum/audi-a3-s3-cabrio/113661-how-remove-cv-joint-anyone-know.html
    and another
    http://wiki.answers.com/Q/How_do_you_replace_a_cv_joint_on_a_Audi
  9. RGC
    149
    thanks for that :) that first link was the way i was going to tackle it without any info :) looks like the best option without upsetting any of the steering alignment. :rolleyes:
  10. SteveTDCi
    SteveTDCi Active Member
    1,400
    i paid £60 to have mine replaced and that included the parts, undoing the hub nut can be tight and getting it back done up can be just as bad. If its been undone before you might want to change the stretch bolt too.
  11. rickyquicky
    rickyquicky Member
    342
    A little tip when undoing the hub nut.....
    Jack up the car just a little to take the weight of the car, but the tyres are still touching the ground.
    Pop off the alloy wheels centre cap and crack the the hub nut, as well as the wheel bolts, then jack it all the way and then take them all out :icon_thumright:
    Once you done that, pop out the wishbone balljoint, then you should be able to pull the driveshaft spline out of the hub, if its tight, tap the end with a mallet and block of wood to help loosen it. You may need to pop the steering arm joint as well.
    Im sure a lot of people on this forum will disagree, but you dont need your tracking redone afterwards. Dont waste your money.
  12. RGC
    149
    Thats just what i wanted to hear :happy: thanks Ricky
    sounds like a nice easy money saving job :D just the way i like it :w00t:
  13. RGC
    149
    Hi all just a quick update, done the job and all went fine dropped the bottom arm off and used the stretch boot with cone
    also just to add the tracking did need adjusted! it was only out a little but was noticeable when the steering wheel was strait (pulled to the right) amazingly Quick Fit relined it for free with it only being out a that small bit :thumbsup:
  14. discostu49
    discostu49 Active Member
    596
    132
    43
    well bumping this tread as its exactly what I'm after although my boot is the inner just goes to show, bit of digging gets answers
  15. RGC
    149
    Your right m8 search and ye shall find! :kissmyrings:
  16. bentwenty
    bentwenty Active Member Team Brilliant Black Audi A3 S-line owners group
    333
    46
    I case anyone else stumbles across this thread, I've just done this job on my 03 A3 8P BKD, you can get the outer CV off in car by taking the hub bot and winding it all the way in, then when it goes tight, winding it in with a breaker bar. It may seem like it will be doing some damage to it, but it works perfectly!
    You must have the car in gear and the other wheel on the ground (or front brakes locked on, and you must have the staright to the drive shaft, other than that its a piece of cake!
