Changing key fob casing
andy.l Aug 22, 2013
  1. andy.l
    andy.l Member
    224
    20
    Got a new casing for my key fob, going to swap the internals over but will I get any problems, will the key lose its memory to the car so to speak?
    Andy
  2. hades-
    9,482
    646
    be careful removeing the transponder
    if it breaks its ****ed
  3. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Craigynett is in bristol at end of month iirc if you break it or get stuck might be worth pm'ing him.
  4. andy.l
    andy.l Member
    224
    20
    Took it apart, the circuit board is held down by 2 small brass pins, not going to risk snapping it as I only have 1 key at the moment
  5. Greeny233
    Greeny233 It's all about the V8. Team V8 Team Silver Audi S4 Audi Avant Owner Group
    1,094
    385
    Be very very very careful. I tried changing the case on my one and only key a couple of months ago, it didn't end well.
    I put my circuit board into the new case and it never worked again and couldn't be re-programmed so I ended up with a bill for £350 from Audi for 2 new keys.
  6. craigynett
    craigynett Member
    294
    cut the plastic casing away from around where the pins hold the PCB in place. I've done a fair few, much easier than trying to remove the pins themselves
  7. craigynett
    craigynett Member
    294
    oh & i'm in Bristol on Sunday 1st Sept if you need any help with it
  8. andy.l
    andy.l Member
    224
    20
    Ok,thank you
