Changing interior lights to LED
physk Feb 12, 2011
  1. physk
    physk Member
    34
    Hey guys, first post here
    Got an 8L, ive changed the front H1 (facelift) to HID 6000K, changing sidelight 501s when the bulbs arrive (should be about monday/tuesday)
    Ordering some 239s for the number plate
    Now for the inside of the car:
    So far there are
    2x44mm Festoon bulbs (map bulbs)
    2x37-39mm Festoon bulbs (visor bulbs)
    There are a pair of bulbs that look like the one on the right... :
    and say OSRAM 3860 on them..... Can't find LED for these anywhere or not sure what type bulb they are... Any ideas?
    Still yet to look at the boot bulbs, under door light, see if i can do the footwell bulb, and finally the glovebox.
    Thanks guys
  2. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    I will try find what i fit....all readilly available
  3. physk
    physk Member
    34
    Any idea what that bulb is on the right
    Found it before, but lost what it was called. And now just can't seem to find it
    :S
  4. morgan306
    morgan306 Member
    142
    The under door bulbs are 501's, bit tight for room in the holders though so look before ordered slightly bigger led versions ;)
  5. Iyole
    Iyole N/A Rools
    69
    LED Retrofits are BIG in SA. Most of us have done it and we don't come up with errors.
    Here are some links.
    We used to import from TunerDomes
    Great site cause they sell the kits specific to your ride and the bulbs are Plug and Play.
    A local guy now stocks them: LED Lighting | Electromann SA
    Hope this helps.... ​
  6. physk
    physk Member
    34
    Found the bulb on the left hand side
    It's a ba9s bulb
    Gonna check boot and glove box
    I'm trying to avoid kits to keep costs down
    Also for those who have done this before
    Do th LEDs look too bright or is it okay
  7. Dani_B19
    8,975
    321
    So what bulbs does the front interior light run? Are the two big bulbs 39mm festoon bulbs? What about the 2 little reading lights? Also what are the door puddle light bulbs?
  8. physk
    physk Member
    34
    Front interior are festoons I think they're the 44mm and the visor ones are the 39mm
    The small reading lights are the ba9s
    Havnt done the door ones yet but someone said they were 501s
  9. Dani_B19
    8,975
    321
    I think the door ones are 501's, well at least the red side door lights, i dont know about the puddle ones, plus it's raining so cant even check :(.
  10. physk
    physk Member
    34
    How can you get the plastic off the puddle ones
    I can't seem to do it
    Also is it possible to mod in some footwell lights
  11. Westy
    Westy Well-Known Member
    17,440
    1,097
    I've done my puddle lights and I can confirm that they are 501s. You need a tiny flat head screw driver to just lever out the plastic.
  12. physk
    physk Member
    34
    Thanks mate appreciate it
    Any ideas on boot and glove box guys
    If not will go check them in abit
  13. Dani_B19
    8,975
    321
    Boots festoon mate, there the same size as the number plate ones.
    No idea about the glove box, go out and check :).
    I would also love to fit some red footlights under the dash, would look quite nice.
  14. Westy
    17,440
    1,097
  15. physk
    physk Member
    34
    Bulb types so far:
    Door puddle 2x501
    Visor 2xfestoon 39mm
    Map 2xfestoon 44mm
    Number plate 2xfestoon 39mm
    Boot ?xfestoon 39mm
    Small reading 4xba9s
    Glove box
    Optional
    Door red light 2x501
  16. Dani_B19
    8,975
    321
    Boot you need 2, one at each side.
  17. Dani_B19
    8,975
    321
    BTW, where's everyone buying their led's from that doesnt cost the earth?
  18. Westy
    17,440
    1,097
    I was just going to get mine from ultraleds as I've used them before.
  19. physk
    physk Member
    34
    I'm gettin mine cheap from
    Wardenjp.com
    Or maybe
    Dealextreme.com
    Both are from china so saves costs
    Will take time but are good sites
    Alot of vag and seat Leon boys use wardenjp
  20. Westy
    17,440
    1,097
    When you've priced up the whole above list from these sites can you let us know. Cheers.
  21. physk
    physk Member
    34
    Will do guys
    I'm just gonna go check the glovebox and whether there actually is one
    Im not sure ive got one... or its gone lol
    Also guys
    there might be differences depending on the type of bulb you go for
    SMD(brighter) vs LED(Not as bright?)
    Would anyone know the differences between the two?
  22. morgan306
    morgan306 Member
    142
    Someone correct me if I'm wrong,but SMD is short for surface mount diode,so a board mounted led.Not necessarily brighter.Brightest LEDs I've come across are CREE LEDs.
  23. physk
    physk Member
    34
    Ive got a cree led torch used for little late night car duties, and can say its super bright
    never knew theyre was car cree led bulbs?
    also glove box bulb is a festoon 39mm
    will check out how much it comes out for all the bulbs soon :)
  24. physk
    physk Member
    34
    Full Audi a3 8l bulb kit
    Sidlight led 501 x 2
    Puddle light 501 x 2
    Red light near puddle 501 x 2
    Map reading bulbs*
    Festoon 44mm x 2
    Interior reading lights x 4
    Ba9s
    Visor x 2
    Number plate x 2
    Glovebox x 1
    Boot x 2
    Festoon ba9s x 7 (I ordered 8 just to keep a spare)
    Total:
    Festoon
    39mm - 8
    44mm - 2
    Ba9s - 4
    501s - 4
    £25 delivered
    On*
    warden_jp2002 Stores Auto LED bulbs
    Dealextreme was an effort finding the sizes*
  25. 666markyboy
    666markyboy Well-Known Member
    1,200
    49
    I fitted some of these Flexible LED Strip SMD Red - 10cm Piece - 12v - UK on eBay (end time 18-Feb-11 20:11:51 GMT) under the dash to illuminate the footwells and under the back of the front seats to illuminate the rear footwells they give the same red glow that you have under the ashtray and combined with the ambient light mod look really good and very OEM the wife liked them that much she made me fit some blue ones to her electric blue Vauxhall Tigra
  26. physk
    physk Member
    34
    Could you post any pics to show how they look?
  27. 666markyboy
    1,200
    49
    leave it with me i'll see what i can do... have to wait till it's dark and not the easiest to get a good picture of.... looks good though... very OEM like i said and not really bright and chavy.... looks good with red mats too
  28. physk
    physk Member
    34
    Seems like they were hard to fit on.
    what did you have to do.
  29. Dani_B19
    8,975
    321
    Have you got any pictures, how did you connect the bulbs up? Would love todo this.
  30. Dani_B19
    8,975
    321
    Also physk your a legend mate, going to get these ordered up tomoz seeming as it's payday :).
  31. physk
    physk Member
    34
    No worries budds
    i thought itd be interesting having a list with all the bulbs
    searched everywhere but couldt find em so decided to check them all out myself
  32. 666markyboy
    1,200
    49
    Ok here ya go.... sorry about the pics as i said i'm pants at taking pictures at night so the first 2 are over exposed and look much brighter than it realy is and the last one is under exposed so is a little too dark but it's getting there... anyway you get the idea
    all i used were those strips of led lights from the Ebay link they come with about 5 or 6 coloured leds on a thin flexible strip that has double sided tape attached to it so you can stick it anywhere you like , they are already wired up with about a meter of wire and i just patched it into the wires that feed the ashtray lamp so they come on with the sidelights
  33. 666markyboy
    1,200
    49
    Actually looking at them now number 2 pic is probably a good likeness :)
    Ohh and i have Red car mats
  34. s3dave
    10,110
    736
    They look great, is it like a UFO on country lanes....lol
  35. Dani_B19
    8,975
    321
    I'd say no3 looks like a black out, no lighty, no likely, lmfao.
    So how did you get to the ashtray wiring? Any links to the lights you got, had a look on ebay and just frows up ****.
  36. physk
    physk Member
    34
    Hrmm, im not sure if its the pics or not but they look abit too bright too my taste
    yeah lol no3 looks like total darkness
  37. S3KO4
    S3KO4 Member
    850
    Too much red makes you angry.. I would stick with the standard one, or ice white to cool my brain down. :)
  38. 666markyboy
    1,200
    49
    They aint that bright.... pics were took on a tripod with long exposure .... look how bright the dials are , the Head unit and Aircon try to tone it down to how they would really look and you get the idea.... hell i aint tryin to sell you owt .... people just said they had thought about footwell ilumination and i have allready done it and it's very subtle maybe a video might be a better idea ?
  39. 666markyboy
    1,200
    49
    if you look at pic 2 ..... look at the lighting from the OEM light under the ashtray....... we all have that light but it looks really bright in my photo because it's taken at night with long exposure....... imagine the same light in the footwells and thats what i have just a dull red glow
  40. Westy
    17,440
    1,097
    That website above is one of the most confusing sites i've ever seen. It looks like it was designed by a child!
