Changing Indicator bulbs????
Stepho Sep 19, 2005
  1. Stepho
    Stepho Member
    444
    Anyone Know how you get in to replace the front Indicator bulb on a 1.9 Tdi? Had a look tonight but can't seem to see a way in to replace on any side. Is it a case of removing the headlight? /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/confused.gif
  2. simon_golf_tt
    simon_golf_tt Member
    249
    Unfortunately yes - you need to remove the headlight. However it's easy !
    Remove the top two torx screws that hold on the headlight and then loosen (no need to remove) the lower two screws which are down the back of the light. Pull the headlight forward to remove. You will probably find that you don't need to unplug the loom. Maybe cover the bumper with a cloth and rest the headlight on the bumber while changing the bulb.
