That is in good nick. Mine looked worse than that at 20k!
I'm going to check my wife's Mk5 GTi at the weekend, I might even use the one I took out of mine if hers is bad.
If you buy an ECS Tuning magnetic sump bung (assuming it had worn through) this may pick up the worst of it. Some fuel will get by into the oil, but you'll likely smell it more the older the oil gets
Does the oil require to be changed if I'm only replacing the cam follower (last oil changed 5k, last November)?
not off the top of my head. I think Audi only sell the pump as a complete unit, not as bits.
Didn't take that part off on mine, but when I get back to UK I'll peel my old unit apart to see if one is in there and if so what size it is.
