Changing fuel filter 98' 2.5tdi
Discussion in 'Diesel forum' started by steven1, Oct 12, 2007.
  1. steven1
    steven1 New Member
    Oct 11, 2007
    Hi people, fuel filter on my 98’ 2,5 TDI needs to be changed before winter .
    I was not able to find answers to couple of questions. So please help.
    Do I need to fill the filter on that model with fuel before installation or bleed the air out of it before connecting all tubes (I do not know if my car has additional electric pump in tank)?
    Or I just install the filter, connect all tubes and the car somehow itself gets rid of the air in the system.
    Another thing:
    Audi specifies also that occasionally the water should be removed from filter. Is that what the tube with the screw on the filter is for. Is the right procedure that I remove the screw from the tube end, turn on the ignition and then the water/fuel is pressed out through that tube?
    Thnks in advance for any clearification.
  2. Advert Guest Advertisement
  3. enda1
    enda1 Member
    Jan 17, 2006
    436
    If you pm me with you email address and car type and engine code I'll send you the procedure. it'll probably be Monday before I get back to you as I'm away for the weekend
  4. steven1
    steven1 New Member
    Oct 11, 2007
    Thanks Enda1.
    In the weekend I will reacquaint myself with the smell of tractor fuel.
