Changing front indicator bulbs 2003 A3
Garf Mar 24, 2010
  1. Garf
    Garf Member
    39
    How easy is it to replace the indicator bulbs on the front lights? Had a look under the bonnet and there doesnt seem to be much room.
    Is it a headlight out job? Any advice or guide would be helpful.
    cheers
  2. c_w
    c_w Well-Known Member
    1,163
    87
    I believe you have to drop the arch liner down and access from the wheel arch.
  3. Staz
    Staz is a retronaut Staff Member Moderator VCDS Map User
    6,206
    65
    Yep it's wheelarch liner down (not a particularly hard job BTW) or very very skinny wrists.
  4. Lee_R
    Lee_R Active Member
    2,499
    12
    yeah done this, jack it up, turn the wheel in, remove the front edge of the wheel arch liner and you should be able to get in. Taking the wheel off gives you more room and seeing its your first time at changing them, i'd advise taking it off!
  5. Garf
    Garf Member
    39
    cheers, will do it at the wk end then
  6. Staz
    6,206
    65
    I wouldn't bother taking the wheel off personally. I've had to get in behind there when taking my bumper off and I simply put full lock on.
  7. Lee_R
    Lee_R Active Member
    2,499
    12
    make sure you wearing some sleeves too, the wheel arch liner will rip your arms to ribbons if your just wearing a t shirt!
  8. davej_anderson
    davej_anderson Member
    261
    I must have gypsy hands as I found it fairly easy to get my hands in and change the bulbs without going through the wheelarch liner method
  9. Staz
    6,206
    65
    I think it depends on the engine also.
  10. c_w
    1,163
    87
    Possibly depends on the headlights too as the connector for halogen lookis right in the way but for bi-xenon it's on the top so might not be as much of a problem?
  11. Sarah's A3
    Sarah's A3 MODERATOR V6 S3 Hybrid Staff Member Moderator
    5,920
    30
    I didnt bother removing arches, loosened headlamps and managed to get hand in! Few scratches though lol
  12. Garf
    Garf Member
    39
    i have big hands lol
    ill take the arch liner out i think
