Changing front discs and pads on 2004 A4 1.9tdi
YOGITHEBEAR Jun 17, 2013
  1. YOGITHEBEAR
    YOGITHEBEAR New Member
    Hi all
    New to this car maintenance lark and just wondering how long this job should take me and if there is any tools in particular I will require?
  2. SPARTAN91
    SPARTAN91 RED FIVE STANDING BY Regional Rep Gold Supporter Team Silver Audi A3 TDi
    484
    164
    43
    You will need a brake caliper rewind tool or a piece of thin flat wood and a g cramp to push the piston back in and some times it advised to undo the lid on the brake fluid res as the fluid is forced back into it but be carefull it doen,t overflow.Time taken will depend on how long it takes to undo the caliper bolts and the harder ones are the carrier mounting bolt, use the longest leverage bar you can.
  3. Tom_B
    Tom_B Member
    292
    20
    One hour each side plus a cup of tea in the middle. Decent quality tools epsecially the allen bit to remove the pins that carry the pads. Watch out for the wear sensor cable and how it sits in its holder. Torque everything back up and enjoy one of the best upgrades that can done in two hours. Get your pads and discs from All German Parts in Leeds.
  4. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    363
    52
    Invest in a 7mm Draper Allen key brake tool. Essential bit of kit. Also Lockheed red grease (to lube slide bolts). Remember to thoroughly clean everything prior to installation, and wipe new discs with methylated spirit.
  5. aragorn
    17,956
    701
    You dont NEED the 7mm allen key, you can take the whole caliper off as a complete unit, and refit as a complete unit. Its worthwhile to use the 7mm key though, as it means you can take the sliders out, clean them up and regrease them.
