Changing cluster in a A3 8L 2001 Y reg
AudiLeon Jan 16, 2012
  1. AudiLeon
    AudiLeon Well-Known Member VCDS Map User
    2,196
    160
    Hi, the wifes cluster is playing up. The temp sensor doesn't read correctly. I've tried a new sensor and still the same.
    Sometimes it's fine sometimes it reads 110 to 120.
    What is involved with changing it? I have genuine Vagcom.
  2. towcestervag
    towcestervag Member VCDS Map User
    165
    you will need to reprogramme the keys!
    vagcom/vcds wont retrieve the 4 digit pin
    have you checked the dash with vagcom
    17 dash
    08 measuring blocks
    then read data for temp to see if it corresponds with temp guage you may have another fault?
