Changing centre brake light on A4 Cabriolet
sva19 Nov 10, 2009
  1. sva19
    sva19 New Member
    Can someone tell me how I can get access to the centre brake light on the A4 Cab, it is located in the boot section, but opening the boot I cannot see any access points. Any pic would be useful thanks
  2. gjwell
    gjwell Member
    82
    Hi,
    There is a round plastic cap in the boot behind the light, twist this and take it off. Then undo the bold behind it. Once the bolt is all the way out gently wiggle the light cluster and the whole thing should hinge outward away from the car. You can now access all the bulbs from the back.
  3. pjmspeedy
    pjmspeedy Dude, what's mine say ?
    1,058
    I think he means the one in the boot lid it self and not the clusters.
    I've never looked at taking that out but I guess there's some clips somewhere to undo!
  4. sva19
    sva19 New Member
    Hi Yes its the light in the boot lid. Any ideas anyone?
  5. 1wheelonly
    1wheelonly cabriolet VCDS Map User
    2,386
    112
    remove the boot lining, youll need some force as the clips are strong! underneath this youll fing the looms, the boot lock etc.
    it is like a double skin, the third brake light is fixed in inside there, all will become clear once youve removed the cover.
  6. sva19
    sva19 New Member
    Thanks all.
    I opened the inner lid cover just a few screws in handle, took out Triangle and bolts and removed lid by prising avay the clips.
    Did not have to change bulb was just loose connection. But the light has around 6 screws.
    Hope link below helps others
    http://www.fixya.com/cars/t2793940-access_centre_brake_light_a4
  7. RMH1A4cab
    RMH1A4cab I'm in Cruise control
    551
    19
    Resurrecting an old thread.
    I keep getting a fault on my dash saying the boot light has gone this only happens when it rains it then clears within a few minutes , I've already had the light out and cleaned all the connections and sprayed it with gt40 which cured it for a month or two, new it's back I think I need a new light anyone know where to get one from apart from audi.
  8. GoneSouth
    GoneSouth Member
    153
    15
