Changed injectors 2.0 tdi ,but still not running right
james1985 Mar 31, 2013
  1. james1985
    james1985 New Member
    10
    Hi i have a 2007 a3 2.0tdi engine code BMN has done 80,000, it had injector failure on injector 1,3 &4, i changed all four injectors for new ones and a new injector wire loom all from tps.
    the car now starts and drives, but goes into limp mode, with the coil light flashing, code shown is 000665 boost presure regulation p0299 -006 control range not reached.
    once the coil light comes on it runs very rough and usually cuts out and doesn't restart with out the code being cleared, and then some times it takes a while.
    This is the only fault code,
    does anyone have any ideas please?
    thanks james
  2. Rhyso
    Rhyso Well-Known Member
    1,518
    315
    You changed them yourself??
    there is an official recall on these injectors by Audi.........
  3. james1985
    10
    yes the car is a cat d damaged so they wouldn't do it under the recall!
  4. Rhyso
    1,518
    315
    mozza1202 likes this.
  5. james1985
    10
  6. Rhyso
    1,518
    315
    that i do not know. Just thought to start from the beginning by checking the installation then that may help :)
  7. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    very odd to have 3 injectors fail i would say
    shouldnt matter if cat d i would go some else
  8. TDI140
    TDI140 Well-Known Member
    1,626
    174
    Audi dont need to know its cat d all they need to know is that if they dont book it in your going to phone vosa and report the garage then they will fear you and book your car in and give you courtesy car i had a a1 1.4tsi loved it lol ring then up tuesday and say vosa said cat d or not the car can be booked in
  9. james1985
    10
    thats great, i will give them a call and try that, thanks for your advice
  10. james1985
    10
    I had it scanned on vag com and it said three but some one told me it could have just been a faulty wire loom,but i thought i would just change them all to get the problem solved! But no its not much better.
