Juned Hussain
Hi,
I have recently been told that i need new front lower wishbones. I have bought a pair and later find out that theres 2 types of wishbones for the audi a3 which is cast iron and pressed steel. Having no knowledge about wishbones i bought a pair and later find out that the ones i bought are pressed steel. I then checked my car and found out that my original ones are cast iron. I have lost my reciept so i can't return it. So my question is would the pressed steel ones still fit on my car without a problem and is it a straight swap? I've heard that all the bushing and ball joint positions are the same on both so it wouldn't cause a problem. Can someone confirm this. I have attached pictures of both cast iron and pressed steel. You can tell the holes are didferent on both but the bushings are the same
