change a brake light bulb
bearder2006 Sep 17, 2010
  1. bearder2006
    bearder2006 Member
    205
    well how the **** they have changed !!
    well how do you get to change it please :eyebrows:
  2. Bigman
    Bigman Cornish and Proud!
    85
    If you look on the inside of the boot, there should be a little circular cap, prise that off with a screwdriver and then you should have access to a large bolt thing (I forget what tool you need, but it is nothing special) un screw it, being carefull not to drop it, and then the whole light will slide out!
    its pretty simple when you have done it once!
    Adam
  3. DTM1
    DTM1 Member
    60
    i changed one two weeks ago, pop off cap and use locking wheel nut remover ( in tool box by spare wheel) to undo screw.
    Be careful when you prise the 2 clips on the casing to get to the bulb as they seem fragile.
  4. bearder2006
    bearder2006 Member
    205
    thanks will do it to day
  5. bearder2006
    bearder2006 Member
    205
    yes was easy thanks
