centre cap size? and trye size?
S3featesV9 Oct 20, 2011
  1. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    hi all,
    well last night i went and picked up a set of wheels. which to day i dropped off for reburbing.
    they don't come with centre caps so wondering if anyone on here knows the size? i have posted on the rs6 forum too as they're rs6 wheels.
    also two tyres are 225/35/19 the other two are 235/35/19. all four tyres are brand new. i assume they should all be the same size?? others wise the awd might be confused right? or is it ok to run a larger circumference on the back than the front?
    this is one of the wheels:
    cheers guys
  2. liquids3
    liquids3 Member
    931
    22
    Thats only 3mm rolling radius difference that will be fine!,and as for the center caps id just go to audi and get new one's take the wheel part number,be around £35 £40!
  3. S3featesV9
    1,032
    12
    yeah i thought about that but theyre reps. cheers for info on the 3mm diff. being ok. is it better to put the 235's on the back? or front?
    im assuming these wheels will sit further in the arch? as they are ET35? might have to get some spacers too. are these ones alright? or to much?
    TT Shop - 15mm / 20mm Complete Wheel Spacer Kit - Including Bolts and Lockers - Audi TT Coupe and Audi TT Roadster Parts, Accessories, Styling and Performance Tuning
    or these that are smaller set
    TT Shop - 12mm / 15mm Complete Wheel Spacer Kit - Including Bolts and Lockers - Audi TT Coupe and Audi TT Roadster Parts, Accessories, Styling and Performance Tuning
  4. A3Tom
    A3Tom Smell my finger.
    3,504
    14
    Are they genuine or replica wheels?
  5. S3featesV9
    1,032
    12
    replica i believe. couldnt see an audi stamp on them
  6. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,253
    354
    I guess that a 3.5 mm rolling radius difference is comparable to worn tyres on the front with new tyres on the rear so probably shouldnt be worried about to much.
  7. S3featesV9
    1,032
    12
    thats true. ill just stick the larger tyres on the rear.
    just gotta try and get some of these centre caps now, proving to be a right night mare
  8. liquids3
    liquids3 Member
    931
    22
    Yea bigger on the rear!,35et is further outwards,et 50 is neutral neither innor out!,and id still go to audi they should be the same even if rep's!!
  9. Alex C
    3,253
    354
    ? ET 50 means that the mounting face of the wheel is 50mm outside the centre line of the wheel. ET 0 means that it is bang in the middle
  10. liquids3
    liquids3 Member
    931
    22
    Yea but he asked if et35 sits further in the arch it does'nt sits more out,if it was et50 it would be more inward neutral!
  11. JtotheD
    JtotheD Active Member
    907
    26
    I don't have these exact wheels, but i just got blank centre caps for my rs4 reps on ebay, then got a friend of mine who does signage and decals etc to make me some audi signs to stick on. been on there 4 months now and been brilliant, can't even tell the difference. i'll try get some pics up later.
  12. Alex C
    3,253
    354
    ah ok. So how wide are the rims?
