Central Locking
rasA4
Four Rings Mafia Specialist
Deep
When opening the car with the remote, can i change the setting on VAG.COM so that the driver door only opens. My Friends A6 can do this as standard, im wondering if this is possible.
it is possible, thats why they have twin circuits on the pump, one opens drivers door and fuel cap the other opens the rest, if youve got latest vagcom version it will give you codes as you scroll over it, if not ill have a look tommorrow
did have it mine but its a pain, prefere the lock at 15mph setting
thanks for your reply, i have the 15mph closure enabled, does that mean i can't have both?
Yeah it can be done mate, hang on BRB
[Select]
[35 - Cent. Locks]
[Recode - 07]
Enter the coding below
[Do It!]
Write down the existing coding for future reference.
A4 pre-1998 with Delta radio and anti-theft system
Standard Coding: 03468
A4 pre-1998 with Delta radio, anti-theft system and keyless entry
Standard Coding: 12172
A4 1998+ with Concert/Symphony radio and anti-theft system
Standard Coding: 03340
S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry
Standard Coding: 16140
Add the following options to your coding number:
+64 Windows up, sunroof close, and windows down with remote.
-04 One touch unlock of all 4 doors and trunk
-1024 Remove horn honk when arming
+32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
So, if you want to have a 1999 A4 with Concert radio and anti-theft system and keyless entry, and you want to add window control with the remote along with auto-lock, then:
add 03340+64+32= 03436
741
24
691
966
