central locking pump problem
jcb Oct 24, 2011
  1. jcb
    jcb Active Member
    4,132
    13
    in my ongoing issues with my car....discovered a new one.
    pump runs for a good 30 seconds on entry
    boot lock doesnt always open on fob and has to be opened manually with key. after I have done that it seems to work fine.
    so...
    1) could a sticky mechanism be stopping the pump from cutting off as it cant open the boot lock.?
    2) how does the pump know to stop pumping?
    3) would a leak in the boot line be able to cause this?
    4) should I torch this fecking thing and take the £5k it is insured for!?!?!?!?
  2. aragorn
    18,544
    865
    You have a vacuum leak, and if you dont sort it pronto the impeller in the pump will shatter.
    Pump stops pumping once it reaches a desired vacuum pull, or after a timeout if the vacuum pull never happens.
    You'll need to trace round the vac lines and look for a leak. Given the dodgy boot, it might be an idea to start there.
